New Chevron Delo 400
Old 08-12-2010, 04:39 AM
JasonblkZ06's Avatar
So, I have been using Delo 400 since I bought my truck 6 years ago and changing the oil every 6000 miles. I went to buy some to change my oil this weekend and noticed the price dropped from $10.50 to $8.50 a gallon and now says LE on it. On the back it has that lower CJ-4 tag for emissions compliant oil. Is this the same Delo I have always used? Low Emissions usually means less viscosity/protection no? EPA is ruining everything.
Old 08-13-2010, 10:35 AM
supr's Avatar
Since the change to CJ from CI+4, oils for our 5.9 definetly got worse for TBN.
The best CJ seems to be Valovoline PB, with a 10.5 TBN rating, or so. It is also recommended by Cummins. I think 4-5k change for CJ is what most folks do, as the oil is not as good with their additives. There is still some CI+4 around, like at some tractor places. Do a search, there is info out there.
Old 08-13-2010, 10:44 AM
With age comes the cage
Colo_River_Ram's Avatar
The 15-40 multi-grade is still available in drums and 5 gal buckets.. Check with a coop or an oil distributor
Old 08-13-2010, 11:29 AM
dieselfreak21's Avatar
Have had to use the le since around 2007 in my area. So far no problems. change ever 3-5k depending on abuse.
1stgen1993
10-27-2009 10:38 PM
Nor_Cal_Angler
04-15-2008 09:40 PM
CTDowerTN
27
08-07-2007 02:41 PM
eightball
09-14-2005 08:58 PM
015speed
05-05-2003 05:44 PM
Quick Reply: New Chevron Delo 400
