Need help..Want to change cone type Air Filter
Old Jan 9, 2007 | 01:10 PM
HappyGA's Avatar
I have the K&N FIPK witht he cone filter for an 03 model 2500, I want to put an oiless air filter in it's place, so the connecting side of the air filter needs to be the same as the K&N soi I can use the tub to the turbo. Anyone know what filter I need?
I am thinking A&M, but will it interchange with the K&N??
Old Jan 9, 2007 | 01:31 PM
John Faughn's Avatar
I think that the new Amsoil EAA filters are the best right now , There's enough verity that you should find what you need .
This is who I have been getting mine from , about $ 50 , put a cone on mine at the last dyno gathering , switched from a BHAF , made a air box out of the plastic cardboard , same color blue as the filter , when it gets warm out I'll use the blue silly cone to glue the edges together .
http://www.lubedealer.com/twinportsales/home.aspx
Twin Port Sales - Amsoil Shipped Direct
Old Jan 9, 2007 | 02:49 PM
53 willys's Avatar
whats the part number on your K&N filter (just the filter part number)
if you know that I can tell what amsoil dry filter would fit.
Old Jan 9, 2007 | 03:05 PM
HappyGA's Avatar
it will be after work before I can get it, and I will be home by then, I willpost in the morning. Thanks 53
Old Jan 9, 2007 | 05:33 PM
53 willys's Avatar
here it is I found it on the K&N site....
Amsoil Part#EaAU4095
Old Jan 10, 2007 | 10:28 AM
HappyGA's Avatar
thanks a lot...
Old Jan 10, 2007 | 11:24 AM
jrussell's Avatar
Hey 53 *****'s, do you also happen to know the Amsoil part # for an oil-less replacement for the AFE?
Old Jan 10, 2007 | 12:05 PM
Hoss is got a thread going on this also , he's got an 03 , if my memory is on , and the Amsoil , for a drop in [ origanal air box ] was EAA189 , but check before you but , I left a link above .
Old Jan 10, 2007 | 03:47 PM
53 willys's Avatar
It is the same as my intake filter! That I run....
1 amsoil cone filter part#EAAU6080 6"inlet
Old Jan 10, 2007 | 06:07 PM
jrussell's Avatar
Awesome, thanks!
bigragu
Sep 29, 2014 03:12 PM
madhat
Sep 22, 2008 03:23 PM
motomac3
Sep 6, 2007 10:05 PM
drafalske
22
Nov 19, 2002 08:55 PM
