need help for next steps> BOMBING
Old Apr 20, 2004 | 07:55 AM
stonewalldiesel's Avatar
Hey Guys, I need some direction in the bombing process. I've got the gauges, new Volant airbox with Ram Air added, 4" exhaust coming this week. I'm thinking of FASS system but I'm also considering pusher pump with Wildcat maxflow system instead. Edge would probably be next but I also want to maintain the fuel economy. Which of the two: EZ or Comp is better and why?? Injectors is it necessary to change these if I go with an Edge box?? As you can see I have some concerns as I want more jam but I really don't want to tear up my engine or power train. Replies would be great!!!
Old Apr 20, 2004 | 09:44 AM
BigBlue's Avatar
I would go with the max flow kit from rod and an EZ for now. There's no need for a FASS on a basically stock truck. Get a set of Mach 1.5 injectors. You MIGHT, I repeat and MIGHT, help out your mileage IF and only IF you can keep your foot from using all the new found power all the time. The HO trucks respond a lot better to injectors than they do boxes.
Old Apr 20, 2004 | 02:02 PM
hellotbone's Avatar
Get the comp 90% of guys that buy the EZ sell if for the comp
Old Apr 20, 2004 | 05:33 PM
HOHN's Avatar
True... unless you are ONE HUNDRED PERCENT POSITIVE that you won't bomb more than just a tiny bit, don't waste time with the EZ.
The Comp has an EZ built into it, and it's only a few more bucks.
Personally, I would say the TST competition box is the way to go. Very adjustable and no unnecessary timing.
If you tow, go with the TST. If not, go with the Edge.
jlh
jasonstacked06
44
Nov 16, 2010 12:40 PM
jgiachino
16
Dec 7, 2008 03:56 PM
RacerDude
Aug 6, 2006 05:04 PM
robert chilton
Dec 8, 2005 07:27 PM
jonmurr
Jan 24, 2005 01:27 PM
