Need front axle part numbers (doing a rebuild):
Old Mar 28, 2006 | 06:03 AM
Hummin Cummins's Avatar
Yep, going to do the front axle rebuild but need some Dodge part numbers and pricing (my local dealer price matches but need to do it part for part ). Figure since the rig has 110k on it I should just rebuild it all and be good for at least another 110k (my front u-joints have been clicking since 61k miles
1) I need the front hub numbers for the driver and passenger side.
2) The front brake rotor numbers for the driver and passenger side (or the kit number).
3) The front Original Equipment brake pad numbers for the driver and passenger side (the kit number).
Thank you for your help.
Ron.
PS: Already have the front u-joints (Precision 464's) and a greasable ball joint kit. Darn U-joint clicking is driving me nutz.
Old Jan 6, 2009 | 06:08 AM
Precision U-joints
Rear driveshaft 2 Piece precision (takes 2 or 3, verify) Precision #351
Front driveshaft Cardan H joint (takes 2) Precision #232
Front driveshaft @ front axle (takes 1) Precision #235
Front Axle U joints LEFT AND RIGHT (takes 2) #464
Old Jan 18, 2009 | 02:50 PM
Boz007's Avatar
When you say front axle u joints left and right (takes 2), is that 2 per side so 4 total?
Old Jan 18, 2009 | 10:41 PM
mini14's Avatar
2 total, one left one right
Old Jan 19, 2009 | 12:02 PM
Boz007's Avatar
Thanks.
Old Aug 31, 2009 | 06:18 AM
U-joint Follow Up
Wanted to post a follow up for the Forum record
I've been running Precision U-joints for about 125,000 miles now. Have to report no problems. Pulled to Florida twice (from PA). Got them wet a couple times and no failures.
Have to say all I do is keep them greased every 7500 miles with the oil change, AND regardless of milage before I pull (and every 1000miles pulling) or after getting them wet.
Precision HD Greasable Joints:
- Rear Driveshaft Precision-351 (2 or 3 needed depending on driveshaft)
- Front driveshaft Precision-235 (1 needed)
- Front cardigan joint Precision-232 (2-needed)
- Front steering knuckles Precision-464 (1-each side)
pwrtripls1
Jun 2, 2011 07:43 AM
wcbcruzer
May 30, 2011 12:20 AM
mhuppertz
Apr 18, 2010 10:31 AM
LanceD
Oct 27, 2009 08:42 PM
Rick 12v CTD
Mar 21, 2009 10:36 PM
