How much Power Service can I run?
Old Jan 27, 2007 | 01:28 PM
omaharam's Avatar
I will be dynoing on winter fuel tomorrow, and am wondering if all you smart people can help me with how much power service to add to my fuel. The bottle says it raises cetaine 3 points in 100 gallons and 6 points in 50 gallons. Can I add the whole bottle to 30 gallons? I know at a point you can't raise the cetaine number any higher and that at a point it doesn't need to be any higher. Kind of like those people that run 92octane premium gas in a car that only requires 87octane. It doesn't actually add any performance. So is a whole bottle ok, or should it be less or more?
Old Jan 27, 2007 | 02:24 PM
RamWheelsBy4's Avatar
I doubt it would hurt anything to use the whole bottle in 25-30 gallon tank of diesel, but like you said at some point there is no real gain.
I have added about double the 6 cetane amount to tanks going to the track, don't have a clue if it helped or not.
Old Jan 27, 2007 | 04:42 PM
dieselfan's Avatar
what size bottle? i run16oz every time. i ve ran more and didnt notice a difference in MPG, dont know about hp.
Old Jan 27, 2007 | 05:06 PM
P.J's Avatar
P.J
I also run 19 oz.'s, white bottle in the winter.
More probably won't hurt, but likely wont help either.
Old Jan 27, 2007 | 06:49 PM
NB64's Avatar
I've been running 16oz every tank since my second tank. I have almost 50K now.
Old Jan 27, 2007 | 06:59 PM
TurboTed's Avatar
I read an article a couple of year's ago that said at a certain point, increasing cetane actually has a negative affect as far as power is concerned. Maybe someone with a better understanding can chime in?
Old Jan 27, 2007 | 08:10 PM
danc46's Avatar
This might surprise some people, but I've always filled the filter housing with pure Power Service when I replaced the fuel filter on my old 2000 Cummins. It always started up promptly, no difference in start- up noise, and ran smoothly.
I sold it recently at 171K with never a problem with the VP44, injectors, or fuel system.
I don't believe putting in more than the recommended amount will do any harm or do any more good! Anything past 16 oz in a tank is probably just wasting money.
Old Jan 27, 2007 | 08:53 PM
TurboTed's Avatar
That goes to show that using a good, brand name conditioner can't hurt. I've used Stanadyne, Howes, Howes Meaner Cleaner, Ippf, Polar Power, MMO, Power Service winter and summer mixes, and none hurt at all. Yet- the only one I've had Dodge service managers recommend is Howes, and they also sell it at Cummins. I really liked how Stanadyne quieted up the old GM6.5's, and kept the pump form going out. But- it's expensive stuff. Right now I'm using PS winter, and rotating with MMO. My son and brother use MMO exclusively, and I really think it gets rid of some of the clatter. My son's 03 runs as smooth as any truck I've heard. I have a friend whose a heavy duty diesel mechanic. He worked for a company that ran a lot of light duty, medium, and heavy duty diesels. He told the drivers to put in FPPF every fill. He swore by using a conditioner to save those pumps and injectors.
Totallyrad
Jul 19, 2011 07:41 AM
Common
25
May 21, 2007 12:29 PM
WS6HUMMER
Apr 2, 2007 08:12 AM
SSminnow
Dec 31, 2005 09:35 AM
