How much boost?
A set of RV275s will not add boost unless you do something to override the boost control (turbomaster, boost elbow or turnbuckle). If you do this you will need a boost fooler to keep the ECM from defueling and setting codes. Here is where an Edge EZ or other box, that has a boost fooler will help plus you get the added kick of the box.
my truck did set overboost codes with just the 275`s in it.it didnt throw the check engine light,but it did put the overboost codes in the computer.i just drove it by the guage until i put a fooler back on it.mine would go 26lbs. before the wastegate opened.
LooseBoltsRob
31
11-16-2007 02:19 PM
Cumminsdieselboy
10-27-2003 07:36 AM
