How much boost?
Old Mar 19, 2004 | 04:01 PM
Lrdchaos's Avatar
How much boost?
how much boost will a set of 275 injectors add to my truck, will it be enough that it trips codes?
Old Mar 19, 2004 | 04:54 PM
Bob Wagner's Avatar
no, you will be fine without a boost fooler unless you toss on a turnbuckle. then you might
Old Mar 19, 2004 | 05:07 PM
billg's Avatar
A set of RV275s will not add boost unless you do something to override the boost control (turbomaster, boost elbow or turnbuckle). If you do this you will need a boost fooler to keep the ECM from defueling and setting codes. Here is where an Edge EZ or other box, that has a boost fooler will help plus you get the added kick of the box.
Old Mar 19, 2004 | 06:28 PM
bama's Avatar
my truck did set overboost codes with just the 275`s in it.it didnt throw the check engine light,but it did put the overboost codes in the computer.i just drove it by the guage until i put a fooler back on it.mine would go 26lbs. before the wastegate opened.
LooseBoltsRob
31
Nov 16, 2007 02:19 PM
MDMIKE
Jan 18, 2005 10:02 PM
NeedMoPower
Jul 12, 2004 10:04 AM
Cumminsdieselboy
Oct 27, 2003 07:36 AM
Wes C
Dec 24, 2002 12:28 AM
