Mounting the Quadzilla Max Mileage Module
Old Jun 8, 2008 | 02:00 PM
Joe N.'s Avatar
I read in one of the posts that the MMM had to be mounted inside the cab. Is that correct or can it be mounted under the hood? If it is not weather resistant could it be mounted inside a box under the hood? I have a bad back and can't get up under the dash to work like I could in my younger days.
Old Jun 8, 2008 | 02:25 PM
shortbed rv's Avatar
You use to be able to send your Quad in to Quadzilla and they would water/weather proof it so it could be used underhood for a fee. I believe some sent them in to prevent cb problems. I think it is the underhood heat that can kill the electroncis in the box.
The easiest way to go inside is the the clutch block plate.
cemt8
Sep 29, 2008 09:27 PM
MMarty
Sep 25, 2008 06:44 PM
chadsdodge
Jun 10, 2008 12:37 PM
planetdell
Oct 12, 2007 02:44 PM
coparam4x4
Sep 5, 2007 01:01 PM
