map sensior
Old Oct 12, 2008 | 05:10 PM
pwellman113's Avatar
map sensior
i have 99 dodge cummins i am running a edge comp box and my check engine light keeps coming on and my computer is saying that ihave to high voltage going to the map sensior and i will clear it and then it will come back on and it will say that it has to lojw voltage going to it? has any body else have tis problem.
Old Oct 13, 2008 | 05:41 AM
jellis's Avatar
I just had a similar problem. I lost all power. However I had codes p0237 and p0238. I replaced the map sensor and all seems to be well. I am running and edge ez.
Old Oct 13, 2008 | 10:17 AM
Dinner's Avatar
I would check your connections for corrosion, cuts, anything like that. When I had my XZT+ the connections at the MAP got corroded and was throwing CEL. Cleaned up the terminals, put a little bit of electrical grease in there and all is well.
kingofdodge7131
Mar 17, 2003 11:17 PM
BIGOKIE
Mar 15, 2003 10:02 AM
Dusty 96
Dec 2, 2002 03:06 PM
j
Nov 23, 2002 05:51 PM
j
Nov 23, 2002 05:09 PM
