manual transmission fluid
Old Jan 26, 2008 | 10:06 AM
local601's Avatar
I have a 93 manual, can I run synthetic oil in it? Also do I need the limited slip additive for the rear diff.,and can I run a fully synthetic fluid in them as well.
Old Jan 26, 2008 | 10:14 AM
IRoss's Avatar
Yes,(5w20), yes(if yours is a limitd slip, I use the dodge stuff, some guys use the royal purple), and yes....
Old Jan 26, 2008 | 11:48 AM
feveree40's Avatar
Yep, synthetic seems to run smoother in the manual. Synthetic will work in the rear too. Some synthetic gear oil has friction additives in it, but I'd put the dodge stuff in anyway.
Old Jan 26, 2008 | 01:02 PM
local601's Avatar
what seems to be a good oil for the trans.
Old Jan 26, 2008 | 01:36 PM
feveree40's Avatar
5w-30 SYNCORMESH manual trans fluid from amsoil if you want to spend a fortune. Moblie-1 5w-30 synthetic works great too.
Old Jan 26, 2008 | 01:50 PM
BearKiller's Avatar
I have 5-qts Mobil-One 5W-30 FULL-Synthetic in mine.
I noticed Walmart has five-quart jugs of Walmart-brand 5W-30 FULL-Synthetic for less than half the cost of the Mobil.
Seeing as how we are talking transmissions, and not internal combustion engines, I will probably use the Walmart stuff on the next round.
schamran
May 23, 2010 12:58 PM
Gear Poet
May 15, 2009 01:35 AM
ezdemon72
Jul 29, 2005 10:05 AM
EKUgrad
May 9, 2005 03:40 PM
mfdoc911
Jul 21, 2004 09:40 PM
