low speed shudder noise from rearend while braking, almost at a complete stop
Old 05-18-2010, 07:12 PM
reaves11's Avatar
So I have a 2004 2500 4x4 and i have recently noticed a shudder noise while braking and almost at a complete stop, Checked u-joint and it looks tight, thinkin it might be a brake pad, or brake disc trouble. While braking at a higher speed no noise but noise starts when truck is just about stopped, almost like a warped brake disc or something. Any one had similar troubles or noises, any info would be appreciated, thanks
Troy
Old 05-21-2010, 08:50 PM
2006Mega's Avatar
mine is making a similar noise which i think is from a rear seal leaking gear oil onto the rear disc. i have not spent much time trying to figure out exactly what is going on, just thought i would give you some ideas.
Old 05-21-2010, 09:51 PM
cincydiesel's Avatar
Generally a warped rotor will cause the steering wheel to shimmy during braking. I would check brakes first then possibly the hub next.
Old 05-22-2010, 10:24 PM
DodgeDiesel61's Avatar
Troy
Rear most U-joint on rear drive shaft. Do a search for this. I just did one on my truck and my advice is to pull the shaft and pay someone else to do it. Replace both joints while you've got it out. Some stuff is worth broken vices and busted knuckles. This job is not!
reaves11
05-19-2010 08:14 PM
smallwwb
02-11-2009 08:28 AM
Michigan Ram
12-02-2008 09:20 PM
seahawkdodge
20
09-02-2008 12:16 PM
FiverBob
24
08-11-2003 01:46 PM
Quick Reply: low speed shudder noise from rearend while braking, almost at a complete stop
