loud sound
Old Jan 16, 2011 | 11:40 AM
okladodge's Avatar
loud sound
I have a 1991 and every thing runs and shifts fine, but when you let off the gas and then get back on it, it sounds like someone hit the bottom of the cab with a hammer. Anyone know what could be wrong.
Old Jan 16, 2011 | 11:50 AM
ofcmarc's Avatar
Start checking tranny and engine mounts. Then move on to driveline and suspension stuff.
Old Jan 16, 2011 | 12:45 PM
JonathanFleguel's Avatar
bad universals can make a clunk when load is let off then reapplied
Old Jan 16, 2011 | 05:52 PM
GIT-R-DONE's Avatar
Sounds like the universals are ready to come apart. Check your rear drive shaft, better yet, just replace them. Thats how mine acted right before my drive shaft hit the pavement
Old Jan 16, 2011 | 06:09 PM
92smokin blacky's Avatar
Yep check U-joints. Or could be a sloppy rear end or transfer case. Jack it up and rotate tires and drivelines and check the play
Old Jan 17, 2011 | 06:35 PM
hounddogks76's Avatar
Mine does the same thing....have replaced the rear u-joints and it still does it..just thought it was the nature of the beast..rearend is tight also, might just be the transfer case
Old Jan 17, 2011 | 06:45 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
I'm with OFC check motor and tranny mounts.
Old Jan 17, 2011 | 08:02 PM
Onemoparnut's Avatar
If it is extended cab it could be the carrier bearing on the rear drive shaft also.
njmaier
Sep 11, 2006 07:27 PM
piperca
Jul 4, 2006 04:13 PM
tboling
Dec 11, 2005 02:32 PM
HO Cummins
Sep 27, 2004 07:35 AM
B-Peterson
20
Dec 4, 2002 07:03 AM
