Loss of Power & Smoke
Old Nov 29, 2007 | 01:41 PM
justagoodolboy's Avatar
Howdy.
I have noticed over the past 3 or 4 weeks a loss of power & smoke in my truck.
Obviously the 1st thing i checked/changed was the filter, and I was still holding good PSI but changed it anyway. Before I could easly break the tires loose in 2nd gear, but now it wont'. I also would blow quiet a bit of black smoke on a WOT run, but now it only puffs a little until the turbo spools and cleans it up to a very light haze.
I also checked to make sure my pin was not stuck and I was getting good travel out of my fuel cone. All of that checked out well upon my inspection.
Where else should I look?
Old Nov 29, 2007 | 01:54 PM
ofcmarc's Avatar
Don't know which filter you checked/changed but you should check both fuel and air filters.
How's the fuel pressure?
Old Nov 30, 2007 | 02:03 PM
Sorry, should have been more specific. I changed the fuel and the Air Filter is the BHAF which is only about a month old. The FP sits around 15 PSI at idle, and on a WOT run I can pull it down to around 12.5. It was throwing the same results before the fuel filter change as well.
Old Nov 30, 2007 | 02:23 PM
CaptainChrysler's Avatar
Since you looked at the AFC I would assume you checked the line that goes from the head to it. These seem to break/crack alot. If it is leaking you won't get increased fuel with the boost. This was broken on my rig when I got it. Made quite a difference when I fixed it.
RHC
Aug 12, 2019 03:32 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
gocart
Sep 8, 2007 06:47 PM
MR HYDROSEED
Apr 13, 2007 04:46 PM
flstfhog
Nov 5, 2003 07:18 AM
