Lookinf to replace steering stabilizer
Old 03-30-2007, 08:38 AM
BlackSunShyne's Avatar
Looking to replace steering stabilizer
I am looking into replacing my steering stabilizer. It is currently the OEM one. I was looking for a Bilstein dual replacement, but have not been able to locate one. Has anyone got a good place to get these? If they are not available, is there a dual setup thru Kore or others that anyone is using and would recommend? Or, what is the best to go with....open to any and all suggestions here.
I looked at the Thuren set up, and it looks great but at about $500 it maybe out of my price range at this time.
Thanks!
And in other news......this just in, I can't spell the word looking
Old 03-30-2007, 09:22 AM
j684jeff's Avatar
I have the Superlift Stainless Dual set up on mine.Works good and looks good. I think I paid $300 installed at my local custom tire dealer.
Old 03-30-2007, 01:03 PM
ptgarcia's Avatar
I was going to recommend the Carli dual stabilizer setup, but it's $601. There's nothing better out there, though.
Old 03-30-2007, 03:10 PM
I have no doubt that he has the superior product, but after wheels, tires, lift, shocks my budget has taken most of its beating.
Is it possible to install a superlift and run dual bilstein stabilizers in it? I am just looking for the best I can do for what money I have left...
Old 03-30-2007, 03:11 PM
Did you notice an improvment over the "feel" of the steering and all after the install?
Old 03-30-2007, 03:45 PM
ptgarcia's Avatar
You know what, you may want to call Sage and ask him if he can put together a kit with a less expensive shock than the Radflos, like maybe Bilsteins. It would probably save a couple hundred bucks.
Old 03-30-2007, 07:48 PM
PourinDiesel's Avatar
www.solidsteel.biz
Old 04-01-2007, 03:46 PM
cquestad's Avatar
I love my DSS...but would also like a better single stabilizer in the OEM mount...if that is possible.
Maybe just a high end non gas charged shock with the right length/eye size?
Old 04-01-2007, 04:14 PM
OldSmokey's Avatar
Ive been needing to get a new SS also. Is there a big difference between a dual or a single setup?
Old 04-01-2007, 06:52 PM
That is a good question, I just assummed that 2 is better than 1, but if a single can be just as good, I would do that also.
Old 04-02-2007, 03:02 PM
Bump Back to the top.
Old 04-02-2007, 03:04 PM
btolenti's Avatar
I put on a skyjacker replacement steering stabilizer when I went to 315's. Comparing the two, the Skyjacker is beefier.
Old 04-02-2007, 08:15 PM
Strokedelky's Avatar
When I did my lift I had bought the Superlift dual setup, but took it back because you have to cut off the stock mount on the diff. No way I was doing that at this point. After driving with the 37's for a while on our horrid highways I had to do something so I tried the Skyjacker dual and it is definately an improvement over stock. If I had more $ I would have liked the Kore single or the Carli setup, but that will have to wait.
Old 04-02-2007, 09:01 PM
RamWheelsBy4's Avatar
I have a Rancho steering stablizer, it stiffened things up a little after the stock one had around 50,000 miles with the 315s and leveling kit.
Old 02-13-2008, 09:18 PM
jaredb900rr's Avatar
What about this single unit from Defiant for $192, http://www.defianttruckproducts.com/...rt.php?prt=128. I like that it's fairly cheap and looks stock. I don't know what type of shock it is though, so I'm kinda hesitant.
I remember someone (I believe it was ptgarcia) mentioning Carli had a dual setup that was going to work with people who had the Mag-Hytec front covers. Does anyone know when that will be available?
Jared
Quick Reply: Lookinf to replace steering stabilizer
