lift pump questions
Old Feb 28, 2011 | 08:25 PM
CarsonS's Avatar
lift pump questions
how much power can the low pressure piston pump handle. i would really like to stay with a mechanical pump for reliability reasons. im shooting for 350-400 hp. any advise would be greatly appriciated
Old Feb 28, 2011 | 08:37 PM
jimbo486's Avatar
It'll support the 350-400hp you're after. It's good for at least 15psi at idle. Some have even seen them run at 17-18psi once a pressure gauge is hooked up. I haven't heard of anyone drawing it down to 0psi. That's easily accomplished with the stock diaphragm lift pump which is only good for about 3-5psi at idle. You can clearly see a difference between the two pumps. Not to mention, the diaphragm can tear in the stock pump or any stock replacement. No diaphragms to worry about in the piston lift pump.
Txwelder
Nov 26, 2025 01:53 AM
realsquash
Aug 19, 2005 08:52 AM
Txwelder
May 19, 2005 06:10 PM
JackRAK
Dec 6, 2003 11:04 PM
015speed
May 14, 2003 09:27 PM
