lift pump pressure/flow
Old Feb 22, 2005 | 04:02 PM
greenworks's Avatar
my lp is getting noisy and I had a couple of hard starts this week, but the fuel pressure is 15.9 at idle and 8.9 at wot? I did have a 0237 code and cleaned the fittings and it went away, but that is low map voltage and shouldn't effect the starting problem.. or can it?
Lastly if this pump craps out I am leaning toward the fass, and good or bad thoughts from guys running the system
jason
Old Feb 22, 2005 | 07:02 PM
greenworks's Avatar
ok fellas helpme out here the truck takes 5-6 seconds or more to start when it has sat fro 1-2 hours but if runnning and shut off and started agin it fires right again no problem, no lack of power issues. is there a return pressure valve to the tank that might be acting up, i had this problem on my 4.0L jeep
HELP, driving me nuts
Old Feb 22, 2005 | 08:04 PM
greenworks's Avatar
checked the return valve spring bolt to specs and it passed, I noticed that when the lift pump is running without the engine the pressure is 17.9 psi after the pump turns off it drops to 1.3 psi in about 10 seconds, i assumed there would be 10 psi or so to help pressure up quicker for start on the next start, or am I wrong?
Is this looking like a Ip? no codes at all not even companion 01689
Bangingmyheadonthedeskjason
Old Feb 22, 2005 | 09:51 PM
Scotty's Avatar
Top's Younger Twin
I sent you a PM.
Scotty
ralphyboy
Jan 17, 2008 08:35 PM
04ctd
Oct 9, 2006 07:33 PM
8mpg
May 22, 2006 01:35 PM
Lrdchaos
Sep 5, 2005 03:36 PM
tony
Jan 8, 2005 06:10 PM
