Lift Pump Location Question!!
Old Mar 6, 2008 | 09:44 AM
jcmoyer2004's Avatar
I had the quadzilla box on my truck and it crapped out and threw the 1693 code. I contacted my dodge house and they said that it means that there may be other codes and asked if my VP had been changed, i bought the truck with 193,000 and it has 197,000 on it now and has run great till the box failed. The dodge house said a good way to check is if the lift pump was moved off of the engine and put in the tank. Where is the lift pump located so I can check if it has been replaced or relocated. Does anyone have a diagram that i can look at to check on it
Old Mar 6, 2008 | 09:48 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Stock lift pump location:
Number 1
59FORD
Apr 7, 2006 12:28 AM
jlipskoc
13
Nov 9, 2005 10:26 PM
Equalizer 2
Oct 24, 2005 09:44 AM
MARKY MARK
Dec 21, 2002 11:04 AM
