lift pump killing injection pump
Old Jun 22, 2004 | 12:02 AM
cheng's Avatar
ok heres my story
98.5 24v totally stock 120k
driving down the road to work the truck coughed once and then everything seemed fine.
when restarting after work it started right up but idled real rough.
no smoke or anything and we drive home.
next morning no start no nothing. engine cranks but will not start.
I figure out that the lift pump has died ( the impeller has come loose from the shaft )
I replace the lift pump and filter, purge the air out of the system and still nothing. little or no fuel at the injectors.
so, riddle me this batman, is my IP (vp-44?) fried? or is there some other really cheap fix?
thanx
ken
Old Jun 22, 2004 | 12:47 AM
thumper 549's Avatar
by purge the air -did you crack the inj. open (the ez ones?)
Old Jun 22, 2004 | 08:26 AM
cheng's Avatar
I cycled the lift pump 3 or 4 times to bleed the air out and when it woulnt start then I cracked #1,3,4,5 injector lines.
Old Jun 22, 2004 | 09:37 AM
MnTom's Avatar
Welcome cheng. Did you by chance find out if you have any codes? Some trucks you can cycle the key on and off three times and pull the codes. Some you can't. I don't know which ones are which, but if you fill in your sig. you can get more precise help. Once you get the codes (if there are any) you can look here and it might help: https://www.dieseltruckresource.com/...n&onlynewfaq=1
Tom
Old Jun 22, 2004 | 11:11 AM
Haulin_in_Dixie's Avatar
Loosen the banjo bolt at the vp44 and cycle the key till fuel gushes out. Tighten it. Loosen three injector lines, crank on it till fuel flows out all three. If one is flowing you can close it right a way and crank till the others come up. Just a little wetness does not mean they are bled, they need to flow pretty good. This is about all you can do. I have had a couple of occasions that it still took some cranking to get it going, but this is the sequence. Make sure the battery is high, makes a big difference.
If it has fuel at the injector lines the vp should be ok. Best to read the codes if you have problems though.
Old Jun 22, 2004 | 12:01 PM
sjessop's Avatar
It took me a really long time, like almost an hour to get all the air out of the injector lines. It is also really important to have 2 people while doing this. One to crank, the other to open and close the injectors. I found that in the time it took me run around the truck I was getting air back into the lines. Keep at it.
stu...
tommurray
Feb 23, 2014 10:38 AM
Firstgenfanatic
Sep 3, 2007 06:25 AM
Wes in TN
48
Jul 14, 2006 02:55 PM
adgr71
Nov 28, 2005 07:34 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
