Leaking CP3!!!!
Old 03-18-2006, 09:39 PM
bauer500's Avatar
Leaking CP3!!!!
So whats the census on this POS, mine is leaking, never enough to leave puddles on the ground but the wiring harness is a little wet. Do I take it in and have them give me a remaned one that sounds like it will do the same thing next winter or just see what happens when the weather gets warmer? I am really thinking I should have stayed with a gasser now. I thought diesels where bulletproof, seems like there is something else going bad every other day.
Old 03-18-2006, 10:00 PM
one8upcb's Avatar
i had a cp3 changed out already and i still have a leak. come to find out its somewhere on my power steering pump.
Old 03-19-2006, 02:14 AM
cowboy133's Avatar
Its up to you. I had mine changed after leak started. I was worried it would get worse and all that fuel blowing back at freeway speeds under the truck and a 1200+ degree turbo and exhaust don't mix. Why not get it fixed, its warrantied and good insurance you won't burn the truck to the ground. Just my 2 cents
Old 03-19-2006, 06:16 AM
rich2500's Avatar
have it replaced,hopefully bosch will soon fix the issue,other wise what are people gonna do when their warranties are up,buy a new $1200.00 pump every year.
Old 03-19-2006, 09:15 AM
bauer500's Avatar
Thats what I am afraid of! Every dealer that I have talked to around here has no clue whats going on, I really don't even trust them to rotate my tires!!
Old 03-19-2006, 02:45 PM
rich2500's Avatar
you could always do as I did and rebuild it,cost me $20.00 for the seals
Old 03-19-2006, 05:44 PM
B.Law's Avatar
Are the D'max guys having this same issue as well? 2 years and over 100k miles, no leaks on mine yet, "knock on wood".
Old 03-19-2006, 06:51 PM
rich2500's Avatar
I wondered the samething,but the pumps are a little different,because when mine first started leaking I looked into a duramax cp3 as a replacement for my Dodge,because I could get a new one for $800.00 compared to the dodge that was $1020.00 thru Cummins,which is now more due to price increases
adamsmarshall
13
10-07-2008 06:54 PM
Jethro6213
19
07-11-2008 11:59 AM
pullin hard
03-18-2008 03:57 PM
BADBOWTIE
28
07-14-2007 02:36 PM
megacabrule
33
05-10-2007 01:07 PM
Quick Reply: Leaking CP3!!!!
