Leak Above Fuel Filter
Old Feb 4, 2007 | 08:37 PM
ESmithD250's Avatar
Hello, I am new to DTR. I have a fuel leak above my fuel filter around where the water sensor plugs in. Are there are any seals in that piece above the fuel filter?
1990 Dodge Ram D250 CTD 5spd Non - Intercooled
Old Feb 4, 2007 | 08:41 PM
JD730's Avatar
Yes, there's a square o-ring up there. Just did one in fact, your going to need something that fits the large slot thats in the bolt that holds it to the head. Other than that, no real surprises, just clean it up and put the new on in.
Old Feb 4, 2007 | 08:50 PM
ESmithD250's Avatar
Thanks JD, I'm guessing I will need to take the fuel filter off to get to this bolt. I think the bolt is loose anyway considering I could spin the piece that the fuel filter butts up against. What did you use to fit that slot?
Old Feb 4, 2007 | 09:33 PM
tomd's Avatar
Your leak is an easy fix
Take off your filter.
When you do, the bolt/double threaded hollow center might come out with it.
If it does find a way to get it our of the old filter w/out damaging threads. I used cloth with channel locks. Not hard and was not torqued on enough to damage threads.
Once you do that take the hollow piece (making sure you have the right end) and thread it up into the block with spacer (making sure the upper Oring is sealing) hand tighten it up there and use a way to tighten as good as possible again w/out damaging threads.
Once that’s all done you now have a solid base to thread your fuel filter onto and no air in the system and fuel loss.
Old Feb 5, 2007 | 03:25 PM
I used a 9/16" drag link socket, but good luck finding one of those.
Old Feb 5, 2007 | 05:23 PM
tomd's Avatar
It shouldnt be to hard making a tool for the job. A little welding.
Old Feb 5, 2007 | 06:44 PM
olddodgetrucks's Avatar
socket
Drag link socket that tells your age,ill bet 80% of readers dont even know what that is.
Old Feb 6, 2007 | 05:40 PM
I inherited it from my grandfather and never thought I'd find a use for it.
Old Feb 7, 2007 | 08:56 AM
Chrisreyn's Avatar
Most any tractor shop that services older Ford tractors can get you one. I have two that I picked up over the years for adjusting the bands on an old Ford S-O-S transmission...O'Reilly's Auto Parts also carrys them
Old Feb 7, 2007 | 10:20 AM
dumptruck200's Avatar
Red face Drag Link Socket
Okay, I'll bite. What's a drag link socket? (and I thought I was old!)
Old Feb 7, 2007 | 10:23 AM
Chrisreyn's Avatar
Picture a standard socket with a flat bladed screw driver sticking out of it....
Old Feb 7, 2007 | 12:37 PM
Drag Link Socket
Thanks Chrisreyn.
I bought a 1/2 drive that had one of those in in the seventies. Never knew what it was for!
ironduke2
Feb 10, 2012 09:53 PM
ARbowhunter7
Apr 7, 2011 10:28 PM
Brian.B
Jan 31, 2011 06:04 PM
offroad00
Nov 12, 2008 06:50 AM
yomitch
Nov 16, 2003 11:36 AM
