Leaf Springs kicked my arse!
Old 10-30-2004, 10:03 PM
Crimedog's Avatar
Leaf Springs kicked my ****!
Holy Crap! Insurance adjuster and I finally met and came up with a reasonable estimate, and so I brought the truck home and started working on it today. It took me all day just to get the leaf springs out Subtract a few hours for running around and making phone calls to try to find some u bolts, nobody had any Whover the assembling genius was on my truck, I want to thank them for putting the leaf eye bolts in from the inside to the outside, so I had to pull the tank halfway out Also for putting the rear ones in so that they hit the reciever so they had to be cut, too Our sawzall (not really a Sawzall- it's an off brand) petered out trying to cut the first bolt so I got fed up with it and finally fired up the arc welder to crank 'er up and cut them. Well it took me a half hour to find the extension cord for it Finally got one spring out and then the other side the bolt was seized with the metal piece inside the bushing so I had to cut the shackle in half to get it out - with the arc... Then I could cut the bolt in half and I was done. As I was straightening up a bit so I could move around a bit I dropped the air compressor hose on some hot metal and melted a hole in that... But, both springs are out and now I just have to put the new ones in tomorrow. Hopefully it won't be as eventful
Just a little heads up for folks who are thinking of swapping leaf springs, be prepared to cuss!
Old 10-31-2004, 05:31 AM
sherod's Avatar
I love the little jobs . My wife has mentioned several times, " I thought you said this wouldn't take long".
Good luck putting it back together.
Ed
Old 10-31-2004, 08:12 AM
mikmaze's Avatar
while they are out ya gonna get some taller springs for it? sem like a chance to "rise" to the ocasion.... hmmm then that puts ya to the front end issue........... never ends does it? watch the knuckles and good luck.
Old 10-31-2004, 09:41 AM
tool's Avatar
I am willing to bet putting them back in will be no better.
I remmeber replacing springs and shackles on my F*rd.
No fun.
Old 10-31-2004, 10:37 AM
MARKY MARK's Avatar
Yikes! I hope mine don't give me that much trouble. I'm going to take mine out soon to have them re-arched since the Skyjacker D25's raised the front about an inch higher than the back.
Old 11-01-2004, 05:52 PM
doodah's Avatar
They can re-arch springs? where can they do that at? I might have to look into that!
Old 11-01-2004, 06:31 PM
Crimedog's Avatar
It went a lot better putting them in considering I put the bolts in the easy way I took an old leaf and added it to each pack (2nd one fromthe top) and it raised it up a good 1-1.5 inches. The truck went into the frame shop today and sure enough the axle proved bent and they have 6 hours of frame straightening to do I drove it down the road and it drove fine, but I'm not going to complain about a new axle Only thing that sucks is I can't find a Dana 80 around anywhere close by
Old 11-01-2004, 07:07 PM
doodah's Avatar
Hey, Matt! clean out your mailbox will ya!! tryin to drop you a line!
Old 11-01-2004, 09:10 PM
Crimedog's Avatar
Well CRIPES, Shawn, send me a message then will ya I thought you were going to drop me a line
Old 11-01-2004, 09:32 PM
amartinson's Avatar
Gee Matt, why didn't you just get a new rim and tire like the insurance adjuster said?
Old 11-01-2004, 09:51 PM
Crimedog's Avatar
I totaled up the estimates and If I took the first one, it would have been $475. Right now the bill is about $4200 Just a little bit of a difference...
Oh and Andy, don't forget about the bumper step pad - that was included in the first estimate also...
97catintenn
05-28-2010 08:29 PM
95turbo4wd
12-12-2007 05:59 PM
Joe T
16
06-12-2007 12:11 AM
Crimedog
11-29-2004 05:50 PM
matador
19
05-14-2004 02:57 PM
Quick Reply: Leaf Springs kicked my arse!
