Lamp out acting funny!?!
Old Apr 4, 2006 | 06:31 PM
RYANGRAPHITE600's Avatar
the other day my lamp out light came on for a few seconds then went out with one chime, now today it is chiming with no light most of the time, like 6 chimes in a row, and the light will come on and off at any given time, only staying on a second at a time. COuld it be a bulb getting ready to go, or a loose connection?
Thanks!
Ryan
Old Apr 4, 2006 | 07:14 PM
nathan04's Avatar
The same thing happened to me a few months ago. Mine was the third brake light. The prongs that hold the bulb in place were loose. I took the bulb out and sqeezed the prongs together. Then I put the bulb back in place. Now the conection is really tight. That seemed to fix it. Since then I have not any more problems.
BRayls's Avatar
rear bulbs know to cause this. mine were starting to melt(plastic) allowing bad connection. I bought aftermarket and they were glass no problems since. good luck
Old Apr 4, 2006 | 08:05 PM
rammtuff's Avatar
Grease on the sockets helps also
Old Apr 4, 2006 | 08:51 PM
handymantim's Avatar
Do a search for "lamp out" and you'll get more than you want to read.
The lamp out indicator doesn't check the Center High Mount Stop Light or "third brake light".
Hoss
21
Dec 3, 2016 02:49 PM
Zach
Jan 19, 2007 07:28 AM
tmacie
Nov 28, 2005 08:53 PM
Pickle
Mar 26, 2005 11:57 PM
atc250r
Mar 10, 2003 08:19 PM
