Kore HP System?
Old Jun 22, 2008 | 08:26 PM
Jodgg's Avatar
Kore HP System?
want to put a small leveling/lift kit on my 2008 6.7L Megacab--Don't do any major off roading, this lift is for looks only as I want to put some 35s on the rig. I want something I can do myself and hopefully just bolt on...don't have any experience or want to have to cut/weld anything--I was leaning towards the Kore HP Kit -- and mods needed to install this kit? thanks.
Old Jun 22, 2008 | 08:46 PM
j2mk's Avatar
I just installed this system on my truck. It was a very simple install. I took my time and it was done in about 3 hours by myself. I think the ride is a bit more stiff but it does reduce body roll considerably. For the price it is tough to beat. I did install a Thuren track bar, that is the only other modification I made with the kit.
Old Jun 23, 2008 | 09:53 PM
Jodgg's Avatar
bolt on?
was everything bolt on? Any fabrication or cutting or welding? Can a guy do with regular tools in the driveway?
Old Jun 23, 2008 | 09:59 PM
j2mk's Avatar
No fabrication, cutting or welding. I did mine with regular tools in my garage. I would say it was a lot easier than my F250 with leaf springs. If you have any mechanical ability it should be pretty easy.
Old Jun 23, 2008 | 11:34 PM
GlennRMK's Avatar
Like my KORE setup a lot! Rides really nice with the Fox remote reservoir shocks!
Old Jun 24, 2008 | 06:04 PM
Dante221's Avatar
My Kore level kit is great!!
It was installed for me & my mechanic was very impressed with it.
Next week the Thuren track bar goes on. Do not hesitate to get
the Kore kit ... You will be happy!
Regards
Diesel Dante
P.S. : If you're adding 35's I highly recommend four Bilstein 5100's.
The ride improvement over stock is very noticeable!!!!!
Old Jun 24, 2008 | 07:59 PM
Jodgg's Avatar
track bar
what does the thuren track bar do?
Old Jun 24, 2008 | 08:01 PM
chipmonk's Avatar
adjustable track bar that lets you re-center your axle, and gives you MUCH better bushings than stock (rebuildable too).
RiverRat2
Oct 15, 2019 10:59 AM
Chopper_Bob
57
Jan 29, 2009 01:49 PM
sootindiesel
Jun 26, 2008 10:24 PM
Dr.Kayak
35
Mar 17, 2005 12:38 AM
