just bought 12v with 212k on it what should i change first?
Old 04-10-2009, 06:23 AM
p.o.s.'s Avatar
just got a 96 12v 5 spd off the original older who plowed his small driveway for the past 3 years and all miles before that were highway...... what are some things i should change first? im new to diesel motors so im kinda clueless here......
Old 04-10-2009, 06:37 AM
Common's Avatar
BEFORE YOU START IT!
- Tab the KDP
First Things To Do:
- Change the oil
- Check coolant freeze point - change if needed
- Change diff. (front and rear) fluid
- Change tranny fluid
- Check all fluids
Next:
- Turn that thing up and have some fun!
Old 04-10-2009, 12:15 PM
p.o.s.'s Avatar
thanks i planned on doin all that anyways but how bout injectors? it runs and drives fine now the carrier bearing hums a little so ill be changing that
Old 04-11-2009, 05:10 PM
Swarthy Dago's Avatar
what he said, all of it then get the truck to breathe better, bigger proper air filter, gauges are a must, a boost elbow to make more boost, 30 to 35 psi is great, 4 or 5 inch exhaust system, then maybe an exhaust manifold, 3000 rpm spring kit, then a vulcan steering box stabilizer, ck all your tie rod ends, ball joints, track bar for looseness, shock bolts etc. that should keep you busy for a little while anyways. Oh and check the front spring perches, that year and before had a tendency to crack them, there was a recall on that, and congrats, nice truck for ya.
Old 04-11-2009, 05:26 PM
Cummins Freak's Avatar
find a 3:1 steering box and up grade the steering arms and stuff to the stuff off of a IIRC 99-00 3500. Better and bigger and bolts right up
Old 04-12-2009, 08:29 AM
Common's Avatar
O.K. - if you are interested in performance...
You need to open up your exhaust - (cheap route) - cut the hot water tank (muffler and resonator/cat) out and replace with a long section of 3" pipe.
Get pyro and boost gauges - seriously, don't put this off - peace of mind.
Order a plate off of ebay - there is a guy that sells #10 plates real cheap, and from what I've heard, they are very good.
You might start to slip your clutch with a #10 - if you don't want that much power, there is a #12 - but I think you'll be fine with a #10.
Make sure you get a boost elbow - increase your boost MAX to 38PSI.
Don't be scared of installing the #10 like I was - it took about 6 months and a bunch of members offering much help before I took the challenge and went in. I'm no mechanic, but this installation was easy - the hardest part was the break off screw.
If I were you, I'd put the new plate in the SAME location it came out of.
Drive it around for a while and get used to your new found power - you will be VERY impressed.
You don't need an intake right now, but it wouldn't hurt.
Then a set of sticks (75HP)
And any other fueling mods will require an intake and turbo upgrade.
Old 04-12-2009, 01:42 PM
p.o.s.'s Avatar
http://cgi.ebay.com/ebaymotors/Dodge...Q5fAccessories
why is that plate only $30 and the next up is $85 then all the way to $250 next any suggestions?
Old 04-12-2009, 05:26 PM
Common's Avatar
Yeah -go for it.
I paid $200 for mine.
I heard those are good.
Save yourself some money.
rascal
08-23-2011 07:22 PM
mike_ward
08-25-2007 10:30 PM
caper
03-31-2007 06:21 PM
proudpapa97
23
02-27-2007 08:41 AM
NHDiesel
05-02-2005 03:39 PM
Quick Reply: just bought 12v with 212k on it what should i change first?
