JR's little 55
JR's little 55
Is anyone running JR's little 55 I have had one ordered for about a month its going to be here on wednesday Just wondering how its going to compare to my stock turbo which I blew by pushing to much boost thro it Whoever is running this turbo how do you like it how does it compare ta a B1 or HTBG2
i've got 12k miles on mine and love ... was suprised by how quickly it spooled ...
and that's with a tight auto ...
it aughta be great with a 6 speed
no idea how it compares to the others
I have never heard a bad thing said about JR's Lil 55. In fact there was a 5 page thread over on TDR praising it!
If you blew your stock turbo pushing to much boost then I don't think you will have any problems spooling/running a Lil 55. JR modifies them so they spool just like similar smaller chargers, but they move A LOT of air!
Compaired to the two HTT turbos you mentioned, there is no comparison JR's flows more air.
I want one myself, but it will be next year before I get one.
Man I cant wait till it gets here been driving a rented chev for a good month now and I am ready to get back into a diesel truck I am thinking about swapping my mach2 for a set of mach4 JRs got the wastegate set at 45 pounds but said it could spike up to50 do I need to worry about the headgasget
Originally posted by dsl21
Maybe studs would be a good thing how hard are they to put in?
I've heard that the 24V HG's tend to be a little tougher than the 12V's though, probably due to the VP pump not being able to fuel as hard as a P7100 pump. I would try to keep it down to around 40-42PSI.
do you order these right from JR or is there a vendor somewhere...
whats the basic price range they run in?
i wanna get this turbo (ive heard great things) with a comp and my DD3's after the new clutch...looking for a lil over 400hp
what kinda modifications have to be made to the intake or exhaust to adapt this turbo in place of a stock unit??
i am running a stock hx55 right now, i wish i had the bucks to have a adkins version. mine is a lag pig, but once it lights, hold on. the hx55 will move some serious air. i have a 19cm exhaust housing on mine and from a dead stop it will hit 1500 degrees at 120mph and is still pulling like a freight train. i just wish i had jr do his majic with a smaller housing. i have been waiting for someone around here to get one so i could go for a ride.
JR's lil55 with 4in downpipe is right at 2 grand He said it bolts right in should be a breeze to put in
Hey gunnracer what mod are done to your truck
hopefully I can keep my egts under1300 with the lil 55 if I ajust my boost elbow to 40lb will that be enuf boost to run mach2 mad ecm and a pmc3
i have 370s and a #100 style plate with a 215 pump. so i have a good bit more fuel than you. 0 to 120 mph tkes 15 or 20 seconds in my truck, that is a long time to hold something wide open. i think you will be real happy with the egts, the 55 moves a lot of air.
RJ
Originally posted by rjohnson
Could not find it...got a link?
RJ
RJ
J.R. Adkins 'Lil 55 (WOW!)
Got Smoke...Thanks! Tried "J R Adkins"...and "Little 55 Turbo"...with no success.
RJ
Originally posted by gunracer1
i am running a stock hx55 right now.... once it lights, hold on. the hx55 will move some serious air.
RJ
