isspro gauge install help!
this is my second install of an isspro gauge. i have the gauge installed (tranny gauge) when i turn on the lights both gauges light up- but if i use the dimmer switch to lower the lighting- the gauge i just installed makes a noise- like a low buzzing sound- goes away when i move the dimmer switch up to full power-what gives??
so you should have one wire go to a switched +12volt source.(to run the stepper-motor)
and the other should be the gauge lights..witch is hooked to the dimmer switch.
thats my guess
make sense????
thanks for the reply! i thought that too! after the fact! double and tripled checked. wires hooked up correctly gauge lighty dims-but gauges buzzes- turn dimmer switch all the way up-gauge no longer buzzes. will see on the way to work in the monring if the gauge functions!
easinc
03-20-2011 02:04 PM
nvr-enuf
04-18-2010 11:19 AM
RamrBob
01-17-2008 06:25 AM
Mountainmac
11-06-2006 01:15 AM
dctoner
07-27-2005 10:17 PM
