Isn't the fuel tank vented????
Old 05-13-2006, 10:21 AM
Puke's Avatar
I have a 98 24V.
Yesterday when I took off the fuel cap it made that sucking sound...and has never done that before. I am almost sure that these things had some kind of a vent or something. Do they get plugged up????
Where would I find the spot to "unplug" so it will properly vent again.?
Thanx,
Old 05-13-2006, 11:45 AM
piperca's Avatar
The vent is on the tank module. Here is a link to the information and location of the valve.
Old 05-14-2006, 01:03 AM
99 cummins's Avatar
I have checked and re-checked that vent and know it's open, but I still get that pressure release everytime I crack the fuel cap. It is bad enough on long trips that it will lower the fuel pressure readings. To compensate I just leavethe fuel cap on loose.
Old 05-14-2006, 05:42 AM
Break Away's Avatar
Can the fuel line connecters coming out of the tank be replaced with a short hose and clamps ? Mine have some play in them.
Old 05-14-2006, 07:04 AM
doomgaze's Avatar
I have the same problem. The vents are open but I still get the pressure release.
I read in another thread that it could be caused by the injectors not being seated correctly, but I have ruled that out because I recently replaced them all and it did it before and after.
Old 05-14-2006, 09:19 AM
Big Deezul's Avatar
I do the same thing
Polaraco
23
07-07-2011 08:56 PM
stackx2
01-15-2010 07:51 PM
JollyGQ
02-24-2007 05:50 PM
Commatoze
0
10-15-2003 12:33 PM
Commatoze
09-29-2003 05:20 PM
Quick Reply: Isn't the fuel tank vented????
