intercooler questions
Old Jun 26, 2006 | 04:50 PM
SSweeney's Avatar
It has been suggested to me that part of my lack of power and overheating on hills only could be due to a clogged or leaking intercooler. Tomorrow I am having a radiator coming clean out and do a pressure check.
However, I talked to a few radaitor people and they think intercoolers are hard to hurt. They say usually these things dont cause problems. I should mention that I have 190 injectors (bosch) relatively new and a good Bhaf and no oil leaks. I also have a new radiator. What else could it be? Have any of you had issues with your intercooler and what was the symptoms.Thanks
Old Jun 26, 2006 | 04:56 PM
It's relatively easy to leak check them. They don't get clogged unless some foreign objects (shop rag, etc.) get left in the ducting. What kind of boost pressure are you seeing?
Old Jun 26, 2006 | 05:35 PM
SSweeney's Avatar
I do not have a boost gauge. Can I test it without removing it?
Old Jun 26, 2006 | 05:38 PM
Yes. Just remove the intercooler piping and you can cap the ends and pressurize it. If you air it up to 25 psi it should not lose more than 7 psi in 20 seconds. Any more pressure drop than that and Cummins says it is too leaky.
Old Jun 26, 2006 | 06:39 PM
SSweeney's Avatar
So if it does show a small leak or something could this make it loose so much power and get so hot going up long grades?
Old Jun 26, 2006 | 06:58 PM
mhuppertz's Avatar
It would take a good sized leak to cause the problems you are describing, and I think you would hear a leak that big. The sound is usually like a BIG air compressor leak!
Old Jun 26, 2006 | 08:29 PM
wheelo90's Avatar
Here is something simple To check First.
Check the 2 Rubber hoses coming in and out of the intercooler to make sure they are not leaking around them or that they are not cracked. Then check that the air filter is not clogged on you.
Wheelo
Old Jun 27, 2006 | 08:08 AM
SSweeney's Avatar
I checked the hoses and clamps. They seem to be tight and I do not see any cracks. When I pull hills with a load there is a different sound. Because I cannot watch up close while in this situation, it sounds similar to the turbo but under stress. Thats the best way I can explain it.
Old Jun 27, 2006 | 10:41 AM
Falcon1's Avatar
Are you running any gauges? What size exaust are you running. With 190s your stock exaust may be too restrictive. What are your EGT's? With more fuel you need more air. Sounds like you may need more air flow and 4" exaust will help.JMO.
Greg
Old Jun 27, 2006 | 04:45 PM
SSweeney's Avatar
I sprayed some carburetor cleaner around hoses at intercooler connection while runnin at idle. The rpms went up alittle, maybe 100-200 rpms. It seems I do have some size of boost leak. I will be talking off and looking for cracks. It doesnt seem loose. Anyway I would like to thing this is whats robbing my power and causing very high heat.
Old Jun 27, 2006 | 04:54 PM
flashgordon's Avatar
Before you pull the intercooler!!!!!
READ this post https://www.dieseltruckresource.com/...d.php?t=107238
92smokin blacky
Jan 14, 2010 09:23 AM
6Stix
Feb 13, 2009 08:32 AM
mullishacrew
Oct 30, 2008 09:29 PM
Hawthorne
Jul 20, 2007 08:50 PM
Keyser Soze
Jun 15, 2006 04:53 PM
