installing after market lift pump
Old 03-20-2009, 11:21 PM
mrjdm01's Avatar
im thinking about putting a holly blue pump on instead of stock lp any thoughts on how to hook up the fuel line and for the wires i was going to get the power from the fuse box i was thinking id find a fuse that got power only when the key was on and ground it to the bracket where im thinking about mounting it on the frame any thoughts or suggestions???
Old 03-21-2009, 08:09 AM
wurkenman's Avatar
Just extend your stock wires back to the frame rail. Follow the inlet line from the fuel filter bowl back to the tank and cut the line. Be prepared to cuss a swear. There is not much room there and the lines are stiff. Not that bad of a job, but not much room there.
Old 03-21-2009, 08:31 AM
SO5.9's Avatar
Can I PLEASE persuade you not to run a holley blue? Thats absolutely one of the worst pieces of advice floating around on this forum. Makes me sick every time I see a post advocating those pieces of junk. I personally went through 4 of them in 6 months which resulted in my VP44 going bad. Before those who claim to successfully run holley blue's jump on a bandwagon and flame me....please know it isnt just me that has had terrible luck. I can give you the names of at least 2 other members on this board (and 2 others who arent members) who have had the same luck as me with multiple multiple multiple failures. These junkers were never made to pump diesel and come with a 90 day warranty which should tell you a little something. They make the perfect pressure and flow plenty while they last but save yourself the headache and go with at least a Fass HPFP, DDRP , or an AirDog!
Old 03-21-2009, 10:07 AM
mrjdm01's Avatar
Question
so5.9 would you have any idea where i can read more on these other pumps and there cost??? im just like anyone else money is very tight and i cant just wast any (need to make the right choice the first time) the big problem is my truck sits for months at a time till i drive it but when i need it i need it I park it every winter and started it up the other day after sitting all winter and now it idles at 7 psi (3rd lp and one vp44 in 4 yrs ive only put 2500 miles on her in the 4 yrs ive owned her) im just not sure what pump to get its just the blue pump is at the local parts store and ive seen in some profiles on this site people run them i just dont wanna buy another stock lp!! just need the best bang for my buck.any thoughts ???
Old 03-21-2009, 10:54 AM
RAF
RAF's Avatar
I went through 2 lps in about six months of buying my truck. It hurt the VP44 went from about 17 mi per gal to 12. Installed a FASS 150/95 and haven't had a single problem with fuel up to the vp44 the past 2 years. The vp44 is still only 12mi per gal damage can't be reversed but hasn't got worse. Fuel pressure hasn't been below 11 and idles at 14. Bought the truck used with 190,000 and has about 250,000 now.
Just some info for you to think about.
Rich
Old 03-22-2009, 09:03 AM
dahla's Avatar
I just installed a FASS DDRP fuel pump about 2 weeks ago and i love it I haven't been able to pull it below 7psi. thats going up a hill about 6000lbs. trailer with my foot to the floor love it. idles at 14 psi. runs about 9-10psi. normal driving conditions. and best of all only about $250. installs in about 1/2hour using stock location on the engine block
RHC
10-27-2009 06:52 PM
kyle_truck_pull
08-19-2009 05:25 PM
dssimecek
16
06-15-2008 10:37 AM
kyle_truck_pull
02-06-2008 02:57 PM
AKDSLDOG
22
03-14-2003 01:31 PM
Quick Reply: installing after market lift pump
