injector pump seals
Old 01-20-2010, 11:28 AM
JWood's Avatar
injector pump seals
I have read all of the IP threads, and im curious if anyone has found a source for VITON seal kit for the VE?
I have been running a waste oil blend now for about 60,000 miles and ive notice my pump is dripping when its cold. time to take it off and reseal, but I want VITON o rings.
what is the OEM material?
any info is very much appreciated.
Justin
Old 01-20-2010, 11:33 AM
jimbo486's Avatar
nothing but bosch (which is the OEM) is what i used. buy the kit at any fuel injection shop that is an authorized bosch dealer. DGK-121 is the kit you want
Old 01-20-2010, 12:47 PM
Jungle's Avatar
I got mine off Ebay!!
Old 01-20-2010, 02:01 PM
raggmann's Avatar
JWood, where are you located?
I got my DGK-121 ($22.00 CDN) and the one little metric o-ring I needed for my fuel pin WAS viton. That's the nice thing with the Bosch kit, if it's supposed to be viton it is.
Old 01-20-2010, 03:34 PM
jimbo486's Avatar
Jim Lane says the green o-ring for the fuel pin is nitrile.
Old 01-20-2010, 04:03 PM
raggmann's Avatar
I may be wrong, we ALL know it wouldn't be the first time
Old 01-20-2010, 04:09 PM
jimbo486's Avatar
we're all wrong about something at some point.
Old 01-21-2010, 08:00 AM
JWood's Avatar
Jimmbo, raggmann.... thanks for the part numbers. it is available at our Diesel-Electric service shop here in Salt lake.
most shops here want $700 to rebuild the pump. skrew that.
what do they do other than clean it lube it and put it back together with new seals? maybe new DV's... I can do that.
Old 01-21-2010, 01:33 PM
jimbo486's Avatar
would just depend on what's needed. i was quoted $400-$450 for a rebuild. that wasn't including hard parts if any were needed of course. you probably could rebuild it yourself but at least if it's at a shop, they would probably calibrate it after having rebuilt it. of course, you could always take it to a shop to have the calibration done after you rebuild it.
hdcolo
02-13-2015 09:56 AM
ClassA4x4
12-29-2010 08:17 AM
dieselrob
07-07-2006 04:12 PM
Quick Reply: injector pump seals
