Idle problem but only on start up
Old 12-12-2003, 11:25 AM
Paradise Racing's Avatar
Hey guys, need some help. My truck idles way to low when you first start it. I can manualy control the idle and once it warms up its fine. But heres the funny part. After its warmed up, if I shut it off and restart it, it idles to low again until its been running for a few minutes. Help!!!
Also, looking for a someone to do some work to my truck in Maryland. Cam plate, install a 4" exhaust and so forth.
Thanks!!!
Luis
Old 12-12-2003, 12:42 PM
tmiller24's Avatar
Re:Idle problem but only on start up
Sounds like the idle speed is too slow.
Old 12-12-2003, 12:52 PM
How do I correct it?
Old 12-12-2003, 02:44 PM
RCW
RCW's Avatar
The idle adjustment is the vertical bolt on the back of the injection pump on which the throttle bellcrank rests. You cannot miss it.
One thing to consider if your idle is getting low is that your timing may be slipping down below where it should be. That is the usual cause of a slow idle.
It is just fine to turn the idle back up until you get it timed, but then it will idle too fast and need to be turned back down.
Your recommended idle speed is posted on the front corner of the engine, below the injection pump on the CPL tag from Cummins.
Old 12-12-2003, 03:22 PM
BBWD's Avatar
The link below show where it is at and how to adjust it.
http://www.dodgeram.org/tech/dsl/adj...d_Gen-Idle.htm
John (DH)
Ron Paull
11-24-2017 03:59 PM
075point9
12-24-2012 12:24 PM
freds89
05-07-2009 08:54 PM
bsj04
02-18-2008 06:06 PM
Quick Reply: Idle problem but only on start up
