hydroboost
Old 01-03-2007, 12:21 PM
pvdh286's Avatar
hydroboost
I have a 1995 cummins,auto, it does not have a hydroboost, is it possible to add one , where can I get one, how $, this truck is a bear to plow snow with with the present steering? thanks Pete
Old 01-03-2007, 06:37 PM
infidel's Avatar
The steering on your '95 is the same as models with hydro-boost.
Hydro-boost usually refers to the braking assist.
Earlier models had vacuum assist braking.
Old 01-03-2007, 07:42 PM
Greguw's Avatar
You can add it ...I have done it ... You should get a doner truck for the firewall bracket , brake pedal rod , rear section of the power steering pump and sometime mounting bracket .
I have add a return port to a regular non hydro pump assm .
You can buy the unit and hose's ... but with out all the little piece's the big parts do you no good .
Just my 2 cents
Greg
Bobcat698
10-02-2006 09:08 PM
Superduty
12-18-2005 02:45 AM
apache
07-10-2005 03:14 PM
CrewCabCummins
09-07-2004 09:51 AM
Quick Reply: hydroboost
