HY35 vs HX35 Its worth it
Old 01-07-2010, 07:49 PM
Dodgin&Rammin's Avatar
I did a lot of research about these two turbos. My truck being an auto came with a hy and I had problems with high egts with my mods. Some guys said the swap was worth it others said very little difference. I picked up a hx last week for $150. It bolted right up and made a huge difference when in the throttle. My boost went from 26 to 34 and my egts dropped 200-250 degrees when pulling. I took my new 14k toy hauler out for the first time and never would have made it with the hy. I easily hit +1300 degrees with lighter trailers before. With the hx I pulled most hills around 1100. I'm impressed. Anybody with the hy not wanting to spend a lot on a turbo right now I recommend an hx.
Old 01-07-2010, 09:16 PM
Copenhagenjunkie's Avatar
For a few more bucks send that hx up to high tech turbo in SLC and make it a hybrid, you will really like that.
Old 01-07-2010, 09:42 PM
Silver R/T's Avatar
What do they actually do when they do hybrid?
Old 01-07-2010, 09:58 PM
nickg's Avatar
I too experienced excellent results, after installing a "cheap" hx, huge improvement over that hy
Old 01-08-2010, 08:32 AM
It's all explained here
http://www.htturbo.com/cu.htm
Old 01-09-2010, 01:10 AM
Big Blue24's Avatar
The hybrid HX35/40 replaces the stock 54mm 7 blade compressor wheel or 56mm 8 blade compressor wheel with a 60mm 6 blade compressor wheel. If your HX35 was pre 98.5' it has a 56mm wheel and the larger 60mm wheel can be installed without machining the backing plate. 98.5'-02' Hx35's came with a 54mm compressor wheel and the backing plate has to be machined a little bit to accept the 60mm wheel. Also, 98.5'-02' HX35's have the wastegate actuator mounted to the compressor cover so you have to buy the slightly more expensive cover with the cast-in mounting ears to accept the actuator.
91rangerturbo
12-04-2007 11:36 AM
hink
06-01-2007 06:47 PM
bggrndodge
03-22-2007 09:11 PM
moparguy
12-10-2006 11:01 AM
apwatson50
06-30-2005 02:47 PM
Quick Reply: HY35 vs HX35 Its worth it
