hy35 to hx 35
Old Aug 26, 2007 | 09:34 AM
BIGSHOOTER23's Avatar
hy35 to hx 35
what is all needed to change the hy35 to the hx35. and how hard is this to do.
Old Aug 26, 2007 | 09:44 AM
Floorman's Avatar
i had it done just for the moment pretty easy thing if i remember the exhaust side of the turbo is diffrerent and we used a band clamp. what gears do you have i lost alot of quik response with mine but i did gain mid range and hwy
Old Aug 26, 2007 | 09:56 AM
i have the 3.55 automatic in it.
Old Aug 27, 2007 | 06:28 PM
Fishin2Deep4U's Avatar
Just need the turbo and a housing. Get a gasket as it's chaep and the oil return gasket as well.
The overall length and attachment metod to your HY is exactly the same. It's a quick and easy swap!
Dave
Old Aug 28, 2007 | 02:01 AM
1BAD4X4's Avatar
I'm wondering what, if any is the benefit of swapping the two?
Old Aug 28, 2007 | 02:47 AM
If you are running additional fueling over stock, the larger housing allows you to get control of drive pressures. And to be able to change housings is an added benefit.
On a stock fueled truck, the HX will be laggier with the auto and generally not perform as well.
Dave
wldman32
Feb 15, 2006 10:58 PM
MoparRiggan
Jan 7, 2006 06:08 PM
apwatson50
Jun 30, 2005 02:47 PM
Racer57
Mar 1, 2003 09:23 PM
BigBlue
31
Oct 27, 2002 10:17 PM
