hx55 turbo exhaust flange where to find?
Old 01-21-2008, 07:07 PM
banks twinram's Avatar
i am in the process of building a twin turbo setup on my ford-cummins. i am using the stock hx35 and a hx55 i found. the problem i have is i cant find an exhaust flange to fit the back of the turbo housing. it is the one that has 6- 3/8 bolts holding the exhaust pipe on. i dont know where i can find a flange or if i am just going to have to build one. i have it far enough along that i can drive the truck, but the floorboard gets really hot and fills the cab with black smoke. im glad its a 4-door! before the 2nd turbo i was getting 35 psi max boost and 1800+ egt. now i am sitting on 55+psi boost(get scared and let off) with 1200 egt max going 120mph it really helps with egt and spooling sounds great!!
Old 01-21-2008, 07:10 PM
dieselman2300's Avatar
Call this place and talk to Dave. they can get you whatever you need.
http://www.dallasturbo.com/
Old 01-21-2008, 07:15 PM
thanks for the reply. im sorry about the bouble post. i will give him a call tomorrow.
Old 01-21-2008, 07:31 PM
The Guru
Mike Holmen's Avatar
I got my flanges built at a machine shop. I just took in the metal gasket and had them build the flange. Remember to get the bolt holes threads cut on the flange, its helps to get a tight fit and seal up your exhaust leaks.
BigJohnston
06-01-2009 12:42 PM
dieselfuelonly
18
05-24-2007 09:01 PM
mhuppertz
12-13-2004 11:55 PM
Quick Reply: hx55 turbo exhaust flange where to find?
