HVAC Help-Weird Blend door issue
Basically have the same issue winter or summer, Ac or heat. If you are going down the road nice air blows from the vents for say a 1/2 hour then its like some thing blocks the air flow from the fan and air just trickles out of the vents even though the fan is running full bore.
Thoughts?
Check for loose vacuum lines no luck.
Thoughts?
the blend door motor coupler may be broken . look under the heater box on the passanger side by trans hump if you look close with the key on and ac/heater on check to see if the motor just keeps spinning .if so heater treater has a good fix take 1/2 hour to fix
My '03 did the exact same thing.....turns out, the system was low on 134 and the dryer was freezing up. System sounded like it was on OVERKILL but no air coming from the vents.............turn it off to "thaw out" for a minute or so and all was well after that.....until the next time.
Sounds like a blend door problem.Split year is weird My 98.5 has a different actuator than everything I could find on the forums. The "FIX" they sell doesn't exist on my truck. Mine turned out to be a broken vac line, in the hard plastic line across the firewall it was broken but you couldn't see it. Worked intermittently for a few weeks then finally quit all together. I found while tugging on the vac line fittings it finally pulled loose. A small piece of vac hose to splice the break and I was back in business. Any of the soft rubber fittings along the vac lines will cause the same problems if they crack.
I will try a new vacuum line and see if it helps.
Thoughts?
Thoughts?
barttly
Jul 18, 2013 08:39 PM
JWillms81
Jan 12, 2008 09:57 AM
rvluversnc93
Mar 5, 2007 04:12 AM
Tommy93w350
Sep 28, 2006 02:53 PM
