Hp And Tq
Old Sep 29, 2004 | 12:00 AM
1ST GEN.'s Avatar
Hp And Tq
I HAVE A 99 3500 WITH DIESEL DYNAMICS STAGE 3 INJECTORS AND AN EDGE COMP WITH A SCOTTY II BUT I HAVE THE STOCK HX35. ABOUT WHAT HP RANGE AM I AT AND WHAT TURBO WOULD BEST FIT MY SET UP AND WHAT HP COULD I EXPECT WITH THAT TURBO
Old Sep 29, 2004 | 12:11 AM
Cummins4Life's Avatar
380-425hp 800-900tq
less lag
PDR35/14W
Dodgezilla
QuickspoolB1
HTTupgrade
more lag
PDRHX40
Dodgezilla40
LargerB1 configuration
HTB2?
probably add 15-40hp
but I've been wrong before....
Old Sep 29, 2004 | 07:59 AM
RowJ's Avatar
I gained 25 hp going from stock turbo to KSB1-2, with no other changes. That was with EZ and DD3's on an automatic.
If interested in the B-1 line, with the KSB-1 you should see 40 hp, equal spoolup, and lots more mid-high end pull (45-50 psi boost).
RJ
Old Sep 29, 2004 | 04:27 PM
pmtg's Avatar
With my stock hx35, drop-in K&N at the time, 3" straight pipe, and comp hooked as an EZ (the scotch lock had came undone at the time of the dyno and I didn't think about checking it) I ran 366 horsepower and 875 foot-pounds of torque in sixth gear.
With the comp hooked up I still can NOT get over 1250*F on the pyro (unloaded that is). And my fuel pressure drops to only 5psi. I am stumped as to why my truck is this way but will drive cautiously until I can afford a new turbo and upgraded fuel system.
Pat
sleeperman
Mar 8, 2011 02:56 PM
notpowerSTROKIN
42
Nov 10, 2007 09:02 AM
bigthumper
Aug 8, 2004 08:21 AM
Zino
Dec 16, 2003 05:19 PM
