HELP truck dieing randomly
Old Feb 23, 2008 | 10:03 PM
jamesp4962's Avatar
Got a new one here, 2003 cummins, will randomly and seems to be getting worse, die while idleing. Is starting to be a real ***** to restart and when does, a lot of time will run and then die again. Scanned for codes and found P0628, lift pump ckt voltage low. Vehicle is stilll under warranty but dealer is long ways away and am looking for some kind of explanation. Any help is appreciated.
Old Feb 23, 2008 | 10:24 PM
madhat's Avatar
Administrator/Jarhead
That's a lift pump, buddy. That truck ain't goin no where on it's own till you get a new one...
Unless... you clamp a piece of hose to the line coming from the tank that goes into the filter bowl, and hook it straight to the line that goes to the CP3... I would not run it long like that, just if you had to...
Old Feb 24, 2008 | 02:28 PM
jamesp4962's Avatar
So is lift pump failure as common with the 2003 and newer cummins as with the 2nd gen 24 valvers, or is this just a fluke?
Old Feb 25, 2008 | 11:12 PM
griffy's Avatar
mine went 120k
yes its common from what ive been told
Old Feb 26, 2008 | 08:55 AM
sandmanjeeps's Avatar
My 04 went out at 75K miles!
Old Feb 26, 2008 | 10:32 AM
Spooler's Avatar
The issue is only with the 03' to 04.5 trucks. In 05' they went with the in tank LP. If your truck is under 100,000 miles and an inservice date between 1-5 years you can get it repaired under the engine warranty for free. Year 6 and 7 there is a $100.00 deductable. It's not like the VP44 trucks. The CP3 will not be harmed from the bad LP.
Edited: By the way mine dumped at 23,000 miles. Lucky me.
Old Feb 26, 2008 | 10:45 AM
vzdude's Avatar
DTR's 'Go to Guy'
Highly suggest to upgrade at this point! The in tank pumps have performed well, but if you plan on many mods an aftermarket pump may better suit your needs.
blowinsmoke1
May 4, 2010 07:17 PM
White Dodge
Sep 29, 2009 10:36 PM
mcolectd
Nov 24, 2007 09:55 AM
taken5875
Jun 8, 2006 10:35 AM
cummin2tkme
May 8, 2003 07:31 AM
