help!!!!!!!!
Old 03-26-2009, 01:52 PM
bullboy85's Avatar
help!!!!!!!!
im pulling out my hair now. my truck is only getting 11 mpg no matter what!!! i was getting 14.5 mpg pritty regularly using the RBP additive, i ran out and my truck droped to 11 mpg, i knew then something was really wrong, i use to get nothing less then 16 mpg. before anyones askes yes this is all hand calced. ok so first thing i did was add the RBP additive back, didnt help, turned my chip down didnt help, last tank i was towing a heavy trailer with horses in it, it sayed at 11 mpg, now this tank i drove about 200 mi on the freeway, guess what..... 11 mpg agen!!!!!! i cant figer this out. im going nuts, no one has any type of ansures everything i check is normal, im getting boost, no smoke. all im getting from shops here is to start changing parts till its fixed starting with the injectors then the VP44, i dont have that kind of money just to buy and check till its fixed, i need an ansure so i can get it fixed and get on my way.
Old 03-26-2009, 08:11 PM
badme's Avatar
I would say VP44
Old 03-26-2009, 08:13 PM
mishkaya's Avatar
Start with the simple stuff first, have you cleaned your MAP and IAT sensors? May not be the problem, but won't cost much and I do know that a faulty sensor will kill your mileage. Good luck.
Old 03-27-2009, 11:59 AM
bullboy85's Avatar
ya i cleaned them, everyone tells me that same thing over and over here, 150k is alot on injectors, they need changed out.
Old 03-27-2009, 12:16 PM
mishkaya's Avatar
Could well be the problem, and it's always a good excuse for an upgrade!!! You might want to have them pop tested to make sure that's your problem though as 150k isn't really all that much for injectors IMO.
Old 03-27-2009, 12:43 PM
sixguns's Avatar
Is your tire size stock? If it isn't your calculations can be off quite a bit.
Old 03-27-2009, 07:27 PM
bullboy85's Avatar
no there not stock but i have my computer recalibrated for them right after i got them, my milage droped only about .2 mpg average after i got them. all the milage drop happend well after the tires. ya i like that choice cuz i want injectors, but i cant afford to do both.
kcredneck
07-25-2007 10:11 PM
ollie32
06-06-2007 09:21 AM
2500TurboDodge
07-31-2006 04:21 PM
bkay
11-06-2003 10:39 PM
Quick Reply: help!!!!!!!!
