Help with part # and price
Old 07-08-2007, 12:31 PM
05 CTD2500's Avatar
My 5 star dealer is unable to find this for me, can anyone here help? TIA
Old 07-09-2007, 11:57 PM
Prodart440's Avatar
Are you looking for the seal??
Aaron
Old 07-10-2007, 12:08 AM
DTR's 'Go to Guy'
vzdude's Avatar
Part #7 Output shaft seal. You need a new parts guy! LOL
Create Parts List
273-Transfer Case Model 273 [DH3]
210-Case and Related Parts [DH3]
Notes:
NOTES: Sales Codes
[DBB] = All Manual Transmissions
[DEE] = Six Speed Heavy Duty Manual Transmission
[DG0] = All Automatic Transmissions
[ET0] = All 5.9L and 6.7L Diesel Engines
Item Qty Rqd Part Number Qty Line Series Engine Trans Description
1 CASE, Transfer Front
5086 302AB 1 7, 8 DG0 52105650ad
5086 302AB 1 7, 8 DBB 52105651ad
5086 302AB 1 7, 8 DG0 52105650af
5086 302AB 1 7, 8 DBB 52105651af
2 BOLT, Hex Flange Head
5080 859AA 1 7, 8 DG0
5080 859AA 1 7, 8 DBB
3 SNAP RING, Annulus Gear
421 9065 1 7, 8 DBB
421 9065 1 7, 8 DG0
421 9065 1 7, 8 DG0
421 9065 1 7, 8 DG0
421 9065 1 7, 8 DBB
421 9065 1 7, 8 DBB
421 9065 1 7, 8 DG0
421 9065 1 7, 8 DBB
4 CASE, Transfer Rear
5086 332AB 1 7, 8 DG0
5086 332AA 1 7, 8 DG0
5086 332AB 1 7, 8 DBB
5086 332AA 1 7, 8 DBB
5086 332AA 1 7, 8 DG0 52105650ad
5086 332AA 1 7, 8 DBB 52105651ad
5086 332AB 1 7, 8 DG0 52105650af
5086 332AB 1 7, 8 DBB 52105651af
5 DOWEL, Transfer Case
5086 335AA 1 7, 8 DG0
5086 335AA 2 7, 8 DG0
5086 335AA 2 7, 8 DBB
5086 335AA 1 7, 8 DBB
6 6033172 6 7, 8 NUT AND WASHER, Hex, .375-24
7 SEAL, Output Shaft
5086 341AA 1 7, 8 DG0
5086 341AA 1 7, 8 DBB
8 VENT, Transfer Case
479 6910 1 7, 8 DG0
479 6910 1 7, 8 DBB
479 6910 1 7, 8 DBB
479 6910 1 7, 8 DBB
479 6910 1 7, 8 DG0
479 6910 1 7, 8 DG0
479 6910 1 7, 8 EZ0 DDP
479 6910 1 7, 8 DG0
479 6910 1 7, 8 DBB
9 6502081 1 7, 8 CLAMP, Oil Cooler Line
10 HOSE, Fuel And Vapor, 25 Foot Roll 5/16
HFV00 516AB 1 ET0, EZ0
HFV00 516AB 1 7, 8
11 4213328 1 7, 8 VENT, Cap
12 FILTER, Transfer Case Oil
5174 495AA 1 7, 8 DBB
5174 495AA 1 7, 8 DG0
13 FILTER, Transfer Case Oil
433 8943 1 7, 8 DBB
433 8943 1 7, 8 DG0
433 8943 1 7, 8 DBB
433 8943 1 7, 8 DG0
433 8943 1 7, 8 DG0
433 8943 1 7, 8 DBB
433 8943 1 7, 8 DG0
433 8943 1 7, 8 DBB
14 CONNECTOR, Oil Tube Pickup
433 8944 1 7, 8 DG0
433 8944 1 7, 8 DBB
433 8944 1 7, 8 DBB
433 8944 1 7, 8 DBB
433 8944 1 7, 8 DG0
433 8944 1 7, 8 DG0
433 8944 1 7, 8 DG0
433 8944 1 7, 8 DBB
15 TUBE, Oil Pickup
5086 330AA 1 7, 8 DG0
5086 331AA 1 7, 8 DBB
5086 330AA 1 7, 8 DBB
5086 331AA 1 7, 8 DG0
16 CONNECTOR, Oil Tube Pickup
5086 329AA 1 7, 8 DG0
5086 329AA 1 7, 8 DBB
17 TUBE, Oil Pickup
18 SEAL, Oil
433 8942 1 7, 8 DBB
433 8942 1 7, 8 DBB
433 8942 1 7, 8 DG0
433 8942 1 7, 8 DG0
433 8942 1 7, 8 DG0
433 8942 1 7, 8 DBB
433 8942 1 7, 8 DG0
433 8942 1 7, 8 DBB
19 MAGNET, Transmission
368 1601 1 7, 8 DG0
368 1601 1 7, 8 ET0 DG8
368 1601 1 7, 8 DBB
368 1601 1 7, 8 DG0
368 1601 1 7, 8 DBB
368 1601 1 7, 8 DBB
368 1601 1 7, 8 DG0
368 1601 1 7, 8 DG0
368 1601 1 7, 8 DBB
20 PLUG, Oil Fill
485 6641 2 7, 8 DBB
485 6641 1 7, 8 DBB
485 6641 2 7, 8 DG0
485 6641 1 7, 8 DG0
485 6641 2 7, 8 DBB
485 6641 1 7, 8 DG0
485 6641 2 7, 8 DG0
485 6641 2 7, 8 DBB
21 SCREW
4886 473AA 1 7, 8 DBB
4886 473AA 1 7, 8 DG0
22 SEAL, Vacuum Switch
433 8956 1 7, 8 DBB
433 8956 1 7, 8 DG0
433 8956 1 7, 8 DBB
433 8956 1 7, 8 DG0
433 8956 1 7, 8 DBB
433 8956 1 7, 8 DG0
433 8956 1 7, 8 DG0
433 8956 1 7, 8 DBB
23 SPRING, Poppet Plunger
5019 538AA 1 7, 8 DG0
5019 538AA 1 7, 8 DBB
24 PLUNGER
5300 8217 1 7, 8 DBB
5300 8217 1 7, 8 DG0
25 WASHER, Flat
8350 3512 1 7, 8 DG0
8350 3512 1 7, 8 DBB
26 BOLT, Hex Flange Head
27 STUD
5086 570AA 1 7, 8 DG0
5086 570AA 6 7, 8 DBB
5086 570AA 6 7, 8 DG0
5086 570AA 1 7, 8 DBB
28 EXTENSION, Transfer Case
5086 340AA 1 7, 8 DBB
5086 340AA 1 7, 8 DG0
29 BOLT
5019 465AA 3 7, 8 DG0
5019 465AA 3 7, 8 DBB
30 BOLT, Hex Flange Head
31 CLIP
5300 8550 1 7, 8 DG8
5300 8550 2 ET0
5300 8550 1 7
5300 8550 1 7, 8 ET0 DEG
5300 8550 1 7, 8 DBB
5300 8550 2 7, 8 ET0 DEE
32 BOLT, Transfer Case
5086 336AA 1 7, 8 DG0
5086 336AA 24 7, 8 DBB
5086 336AA 24 7, 8 DG0
5086 336AA 1 7, 8 DBB
Old 07-10-2007, 07:16 PM
05 CTD2500's Avatar
VZDUDE, thanks a lot.
so 5086 341AA 1 7, 8 is gonna be the number to give to my moron, right? just want to be sure before I go in there acting all smart
Old 07-10-2007, 09:15 PM
gcssr's Avatar
Is the item you are needing on the front drive shaft , if so it is a dust cover
i don't have a part # but some one may be able to help . if that is the part you need it goes on the case half # 1, front half of the parts break down that has been posted.
Old 07-10-2007, 10:58 PM
DTR's 'Go to Guy'
vzdude's Avatar
Sorry, by the picture I assumed you needed the shaft seal for the rear shaft, and yes that's #7, 5086341AA . The front shaft seal would be #27 ,5086343AA on this breakdown.
Old 07-11-2007, 06:34 PM
05 CTD2500's Avatar
sorry for being unclear about it, its the rear extension housing dust boot that I need (just the cracked rubber boot in the first pic), doesn't seem to be pictured on the parts breakdown so I'm thinking maybe it comes as part of something else??
Old 07-11-2007, 10:26 PM
DTR's 'Go to Guy'
vzdude's Avatar
Yup, it is an intregal part of the seal in post #3 listed as #7, 5086341AA .
Old 07-11-2007, 10:55 PM
gcssr's Avatar
according to original post, he needs the bust boot that attaches to the extension housing, which needs to be removed to get to seal #7, i believe this is as clear as muddy water, i don't have a parts breakdown, but the dealer should be able to find the boot, or just give him the boot and get a new dealer. grant
Old 07-11-2007, 10:58 PM
DTR's 'Go to Guy'
vzdude's Avatar
Look up gcssr. Post #8. The dust boot IS part of the seal. The pictures that Dodge uses for their parts diagrams are very generic in nature.
Old 07-12-2007, 05:00 PM
05 CTD2500's Avatar
thanks for all the help fellas!
77machomopar
01-24-2008 05:30 AM
Silverfox99
04-23-2007 11:43 PM
LanceK
01-14-2007 05:50 PM
Quick Reply: Help with part # and price
