HELP!- Overdrive won't engage (I think)
Old Aug 16, 2005 | 06:51 PM
robox's Avatar
I got my new (to me) W250 about 3 weeks ago and drove it back from Texas to California without any problems, doing about 80 - 86 MPH the whole time.
I installed some Isspro gauges a few days ago - and so I was under the dash screwing around with the wiring a bit.
Got the truck loaded up and ready for the 1000 mile trip to New Mexico and once I got out on the freeway I realized I couldn't get it out of third. Hit the O/D OFF switch - the light in the switch still works, but having the switch on or off didn't make a bit of difference in the trans speed or MPH. Got under the dash to inspect, but couldn't find anything wrong. Checked all the fuses, none were blown. (There didn't seem to be a fuse for the overdrive, anyway) So, I ended up doing 50 to 60 MPH the whole trip, keeping my eye on the newly installed EGT gauge the whole time. But what a pain!
Has anybody had this problem before? Does anybody know if the trans needs to see a VOLTAGE or if it needs to see NO VOLTAGE in order to be able to go into OD? What does the O/D OFF switch directly control? A solenoid? If it is a solenoid, anybody know where that solenoid is? ANY information on this subject will be greatly appreciated!
As far as I understand, this is the A518 transmission.
Thanks!
Old Aug 16, 2005 | 08:09 PM
Begle1's Avatar
Well, I know nothing, but I do remember this related thread from a week ago...
https://www.dieseltruckresource.com/...threadid=74673
That help?
Old Aug 16, 2005 | 09:16 PM
apwatson50's Avatar
There is a lot that goes into the controls for the overdrive, the easiest thing I have done is wire in an over ride switch that I can flip and it locks in the over drive when ever I want.
The slickest thing is to get a shift handle for a 94 and newer truck with the push button built into the end and use that switch to lock in O/D. Do a search and you'll find plenty of info on doing this, or figuring out how to fix the auto O/D
Old Aug 17, 2005 | 09:23 PM
Big Rich's Avatar
My problems of the same type ended up being caused by a bad ground.
Is the speedo working?
Rich
BigDodgeBigHart
Apr 13, 2007 10:26 AM
BigDodgeBigHart
Apr 13, 2007 09:18 AM
robox
Aug 16, 2005 09:15 PM
jman6716
Oct 26, 2004 07:40 AM
