HELP!!! AFC diapram leaking
whats the easiest way to replace this any pics will help exploded diagram or anything i got the diaphram but cant see whats ahead of me not worried just caucious.
Not much. Pull the AFC cover from the pump, pull the pin, unscrew the diaphram from the pin, install new one and bolt it back together. It's wise to loosen the AFC boost reference tube from the AFC top so it doesn't get bent and broke.
No the diaphram won't leak any fuel itself, should be only air in that section. The fuel is leaking from the o-ring on the small pin that rides on your fuel pin. You have to remove the top to repair this leak.
lilsuzuki4x4
Sep 1, 2011 01:50 AM
pwrtripls1
Apr 16, 2010 11:17 AM
PeytonMaterne
Aug 11, 2008 05:25 PM
dan1stgen
Feb 4, 2008 01:02 PM
royta
Feb 15, 2005 10:15 PM
