heater grid o-ring
heater grid o-ring
I noticed today that I have some diesel leaking from around the fuel filter, the filter is tight so I'm assuming its the o-ring in the heater grid.
Anyone have to change theirs that could pass on some advice or directions? I figure I may as well change the fuel filter and if the heater grid is in there somewhere change it as well.
Thanks in advance.
Thanks in advance.
The heater is probably fine, no need to replace that.
The filter spud has a slot across it. The ideal tool is a 9/16" drag link socket, but those are hard to find. Next best thing is a cold chisel ground to fit, failing that a very stiff putty knife works OK.
Thanks in advance.
Thanks in advance.
WHere to buy
Where did you guys find the required o-ring to repair the keak. I went to NAPA and they don't even list the item.
Is this a dealer only thing or a Cummins only part?
SpeedyWS6
15
Feb 2, 2011 07:22 PM
