Having a 3500 towed
Old 05-15-2009, 02:41 AM
kwb
kwb's Avatar
Angry Having a 3500 towed
I had the misfortune of having my 05 Ram 3500 CC Dually 4x4 Auto towed from in front of my house to the impound yard (I live in a EDIT up community with a homeowners association that doesnt allow overnight parking on the street -even in front of your own house!) I forgot to move it one night.... Anyways -
My neigbor witnessed them tow it for about 1500 feet - he said it took them 90 minutes to go that far... The tow truck was towing from the front since apparently he couldnt tow from the rear due to the dual rear wheels. He didnt use a dolly for the rear tires, instead drug the truck down to the end of the street (1500 feet) where he met up with another wrecker, at that point they placed the rear wheels on a dolly.
My question is: Is it possible that they damaged my transmission or rear differntial in doing this? The truck seems fine when I drive it, but that cant be good on the drive train. How can I verify or check for damage???
Thanks for listening to my vent - trust me I am ******. I am going to consult my attorney on this.
Old 05-15-2009, 02:59 AM
HotRodTodd's Avatar
Well normally when towing on the fly, you sneak up on your prey, duck under the truck, disconect the shift linkage and slip it into neutral from under the truck.
Then you hook your tow truck up, tow it to a safe spot where no one is going to hassle you, then hook up your dollies, put on your tow lights, and head for the yard to drop it, and go get another one.
As long as he did it right, should be no damage.
Old 05-15-2009, 03:14 AM
Administrator/Jarhead
madhat's Avatar
You mean it was still in gear when he was pulling it? That's messed up. Lawyer!
Old 05-15-2009, 03:31 AM
kwb
kwb's Avatar
According to my neighbor who witnessed it (it was 2:00am and my alarm was going off) - He said that my truck was being towed from the front and there were no dollies for the rear and that he was going like 1 mph, so I'm not sure what the problem was....
Is there anyway to verify he disconnected the linkage?
Old 05-15-2009, 03:47 AM
Dodgezilla's Avatar
Did your neighbor witness the wheels turning or did the TT drag it down the street with the wheels locked? I would guess that there would be four skid marks leading down the street if he hadn't disconnected something....
Old 05-15-2009, 03:53 AM
HotRodTodd's Avatar
It only takes 10 seconds tops to pull the linkage loose and slip the selector shaft into neutral.
There would be serious flat spots on your tires, and some black skid marks if he didn't.
Old 05-15-2009, 04:03 AM
kwb
kwb's Avatar
One other thing, when I picked up the truck and I questioned the charge, the dispatcher said they had a hard time towing my truck since it was so heavy.
He said that when the first tow truck tried to move it, it was raising the front end off the ground of the tow truck, so they had to send another truck... Is that even possible? My truck weighs 8300lbs -
I'm thinking there is no way that they moved it while in gear, something would have broke....
Wish I would have caught them in the act, on second thought maybe not.......
Old 05-15-2009, 04:27 AM
HotRodTodd's Avatar
Yes it would have been pointing the lights in the sky because most of those contract towers use the smallest truck possible, like a 250 or 350 with a wheel lift because 98% of their work is FWD little crap boxes.
You have to remember, most of the weight of your truck is hanging over the front axle.
I'm sure they didn't harm your truck, they are required to carry a bond and damage insurance, and if someone files a damage claim, their rates go way up. Look under your truck today and I bet you see a shiny spot on the E-clip that holds your linkage in. And if they were in a big hurry, there will be a new E-clip on there, LOL
Old 05-15-2009, 07:30 AM
Jeff in TD's Avatar
If the truck doesn't move when in park, it's probably OK.
I hope to never live in a place with a home owner's association. Rules are rules, but geez, it sounds like it would have been just as easy to knock on your door to remind you to park in the driveway than to call a wrecker...
Old 05-15-2009, 08:37 AM
Mr Bee's Avatar
I lived in a development where they had contract tow company for parking in the street and they paid these drivers double normal if they picked up a vehicle so there were very very agressive... They even towed a 69 Corvette because even though he was in his driveway the nose of his car was extending past the street side of the concrete gutter. The good news was he did not tow the corvette too far because he could not figure out how to drive over my superduty that was blocking him. I got in touch with the owner of the vette and he came out of his house and discussed the value of life with the driver (mostly his). The vette was placed back in the driveway and the tow driver went on to better (easier) pickings. I know the driver was doing his job but the "double rate" is good extra money and then stupidity creeps in and clouds the better judgement.
The vette was at the end of a street where no traffic passed. Not a safety issue at all.
Old 05-15-2009, 12:10 PM
dodgestang's Avatar
I have had my dually drug down my driveway by gravity when I didn't chock it right and was unloading a skid loader....the rear tires didn't leave very noticable marks for the 150 or so feet it skidded...and what little indication they did leave was gone in a matter of hours so on a busy road I would not expect to see a lot of drag indication. But that's just my opinion.
Old 05-15-2009, 12:20 PM
justinsdad's Avatar
it just put alot of pressure on your park pawl, if park still works than it will be fine. You might want to check with local law enforcement about the bill, somewhere there is a governing body that controls rates and prices for impounds and maybe they can point you in the right direction.
Old 05-22-2009, 11:50 PM
DrMike's Avatar
First of all, did you receive what under the laws of California is called "Effective Notice". That is, were you handed a written notice to remove the vehicle from the street by a time certain or it would be subject to removal at your expense. If so, you were an idiot for not moving it. If not, the HOA is in violation of state law which requires such prior notification and, without doubt the HOA is in violation of its own CC&Rs. I would take them to small claims to get the tow and impound charges back at the very least.
An auto is not supposed to be towed with the drive wheels on the ground, even in neutral. I assume you routinely place it in Park when parked. These trucks don't weigh enough to lift the front of even a standard 1 ton tow truck off the ground. If I were you I would be operating off the assumption they dragged the truck either in park or while in-gear the 1st 1500 ft, or 1/4 mile+. That would account for the difficulty they had towing the truck the 1500 ft, as described by witnesses.
I would go see the company and without tipping my hand I would ask them what they did to tow it - why did their tow truck's front end go up in the air - then, "I have witnesses that say you never got into or under the truck, so how the hell did you get it out of PARK?? I would have someone's ***** over this.
How is the trans running?
Old 05-23-2009, 01:52 AM
BigDave12768's Avatar
He doesnt need an effective notice. He lives on a private street. The make there own By-laws. He no doubt has a neighbor that hates his noisy truck and made the call. Also becuase its a private street and you have a company you can call they have to have set prices for tows and storage. So if they charged you extra you can fight that. There is no way a f350 with a wheel lift could tow a 3500 dually even with dollys. The wheel lifts at best can lift 3000 pounds if they are lucky. So if he did get the truck up in the air not only would there be tire skid marks. There would be a metal scrape about 6 inches wide down road. The hydrolics just wouldnt be able to hold the front end that long. Thats why it took 90 minutes to go 1500 feet. He was destroying his wheel lift. I bet he did more damage to wrecker that cost of tow. If the kid is doing trespass towing he knew to pop linkage. He was just to stupid to see the Cummings badge on the side. And there would be now way he could tow it with a wheel lift. And the nose would be straight up.
Old 05-23-2009, 08:10 AM
DarkDesertCTD's Avatar
That's why I dont live in an HOA, and never will! Sorry to hear about the bad luck, hope the truck is OK!
Quick Reply: Having a 3500 towed
