Have a few codes, need help
Old 07-27-2007, 08:53 PM
06 DIESEL's Avatar
I have three codes and I have been able to identify two of them but the third is not found anywhere.
P-2504 -- high charging system
P-0462 -- Fuel level sending unit colts too low
PD412 -- Unknown
What would cause these codes, I know what caused the P-2504, jumping the loader at work and I think it charged me instead of vise versa. As for the other two, what could have caused them and what are the possible solutions. I am still under warranty and have not done any performance mods yet, so I have a perfect warranty.
06 DIESEL
Old 07-27-2007, 09:11 PM
tritont's Avatar
PD412 -- Unknown
06 DIESEL
can't help you with the cause but, here's your last code....
P0412 secondary Air Injection System Valve A Malfunction
Old 07-27-2007, 09:27 PM
DTR's 'Go to Guy'
vzdude's Avatar
No air injection on these that I've seen. Checked and no listing for P0412. Everything else looks right though.
Old 07-27-2007, 09:33 PM
tritont's Avatar
That's was Actron showed. It surely isn't PD like he showed and if it is...maybe it is a Edge induced code
Old 07-27-2007, 09:37 PM
DTR's 'Go to Guy'
vzdude's Avatar
Yeah, kinda wierd. I know you're right on the 412 being air injection like on older GM stuff and Caddys, but I think it is not being listed right for him!?
Old 07-27-2007, 10:16 PM
robmints's Avatar
https://www.dieseltruckresource.com/...d.php?t=146846
I don't know. I'm 99% sure PD412 is what it said. 06 and I did it with a Smarty, but I was the one doing the reading of the display. there was and has never been a DL or box on the truck. totally stock since day 1. Maybe I need my eyes checked. Or 06 should do the reading next time.
Old 07-27-2007, 10:23 PM
DTR's 'Go to Guy'
vzdude's Avatar
Try to get the codes with the key trick and read the codes on the odo screen. It might be a smarty problem reading or showing the right code?
Old 07-28-2007, 05:58 AM
06 DIESEL's Avatar
I am going to go over to Scotts house tonight and we are going to look at it in more detail. The key trick does not work on mine, I have tried several times with no luck.
exwrestler
02-05-2010 09:34 AM
bansh-eman
15
09-21-2009 11:11 AM
sallyman1
08-26-2008 06:20 PM
mbenedict
07-21-2007 09:19 PM
Quick Reply: Have a few codes, need help
