Harmonic Balancer
Old 09-19-2010, 02:07 PM
Fire Rescue124's Avatar
Harmonic Balancer
Ok so today i was out messing with my 01 and noticed that the Harmonic Balancer was wobbling a little.. truck starts and runs fine. what could cause this to happen. i checked the 4 bolts and they seem to be fine. i do see some oil on the motor around the seal for the HB so i'm sure the front seal is shot... hoping i dont have to rebuild this thing
Thanks,
Eric
Old 09-19-2010, 02:36 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Check the two marks if they are still in alignment should be ok as long as wobble isn't excessive. Check for any cracks also make sure torque is at 92 ft lbs.
1 - INDEX LINES
2 - HUB
3 - INERTIA MEMBER
Old 09-19-2010, 03:37 PM
So if the marks are not aligned then what. do i just need to replace the balancer?? Thanks,
Old 09-19-2010, 06:21 PM
Cummins Guru
BigIron70's Avatar
Yes replace it since it shifted and could come off the hub.
CrewCabCummins
11-06-2005 02:33 PM
apwatson50
07-13-2005 08:04 AM
krandall
06-07-2005 06:29 PM
acdc
03-13-2005 09:43 AM
TGCTD
10-18-2004 08:02 PM
Quick Reply: Harmonic Balancer
