How hard is it to put in a exhaust probe
Old Aug 6, 2004 | 04:16 PM
2500TurboDodge's Avatar
what do i need to do to put it in were do i put it do i need to take the turbo off or no are there any pic that i can see
TIA
Dan
Old Aug 6, 2004 | 04:43 PM
infidel's Avatar
Good instructions by clicking this> http://www.tstproducts.com/gauge_install.html
Only thing I perfer to do different is undo the four turbo bolts and slide a piece of cardboard in-between the turbo and manifold. When you finish start the engine for a few seconds to blow out the chips.
The hardest part is worrying about it, it's a simple job.
Old Aug 6, 2004 | 05:10 PM
bigfish's Avatar
Gasket?
Hey Infidel. Just curious...can you unbolt the turbo without replacing the gasket between it and the manifold? Thanks in advance for the reply. Bigfish.
Old Aug 6, 2004 | 09:10 PM
infidel's Avatar
I've always reused the gasket without a problem.
Old Aug 6, 2004 | 11:17 PM
MLR1's Avatar
Yes you can re use the gasket. The torque spec is 25 ft/lbs. on the mounting nuts, in case you need to know.
barngal6
Jul 5, 2009 06:49 PM
SilverRam3500
Feb 10, 2008 11:01 AM
jawsman@sbcglob
Jun 4, 2007 10:27 PM
tomd
Dec 12, 2006 10:56 PM
CTDCAL
Oct 23, 2003 12:09 AM
