What happens if you get dirty fuel in the IP?
Old 05-03-2007, 05:19 PM
wcbcruzer's Avatar
I get this bit of an uneasy feeling ever since I installed my mechanical fuel pressure gauge. I drilled and tapped the banjo bolt, and cleaned everything up real well before I re-installed it. But I keep thinking what if tiny pieces of metal shavings (from the drilling/tapping) get passed the threads and go into the fuel supply. What would happen? Which component is at most risk (injectors, IP, cylinder scoring, etc.?)? Are the holes on the injectors not big enough to pass a metal shaving? I did apply anti-seize compound to the threads. What if that stuff got in there?!
Old 05-03-2007, 05:56 PM
Common's Avatar
That metal can cause an injector to stick open and FRY the cylinder...
Old 05-03-2007, 06:14 PM
wcbcruzer's Avatar
Good point. Well I sure feel better now!!
Old 05-03-2007, 06:15 PM
Geico266's Avatar
What ever would have happened would have happened by now.
I think.
pulltilbroke
01-31-2009 09:16 PM
ArcticWolf
08-16-2005 12:11 AM
Mostwanted
06-18-2003 10:40 PM
John Rodriguez
02-23-2003 07:48 AM
PADZZ
11-20-2002 11:17 PM
Quick Reply: What happens if you get dirty fuel in the IP?
