Handling problem
Old 09-01-2011, 08:44 PM
M1AM14SPUR's Avatar
Handling problem
I am not sure if this is dw or not, but when I am in a slight bend in a road, if there is a bump, it feels like it is skipping and there is a slight front tire bark. Is this the dreaded death wobble?
Old 09-01-2011, 08:58 PM
maxwellp's Avatar
That's Bump Steer, Utube Dodge Death Wobble, If you have it you would know it.
Old 09-02-2011, 10:05 AM
Lost Lake's Avatar
When your front end bounces out of control, everything in the cab gets thrown about and you hang on to the steering wheel in a panic and pray you can slow down..... THEN you have death wobble.
It's DEATH wobble for a reason.... You will know if you have it....
Old 09-03-2011, 08:13 PM
M1AM14SPUR's Avatar
What causes the bump steer? Thanks for replying.
Old 09-03-2011, 08:47 PM
.boB's Avatar
Bump steer is a change in tow with suspension compression and expansion. Unless you've modified your suspension a lot, your bump steer is pretty minimal.
http://www.longacreracing.com/articles/art.asp?ARTID=13
If you're getting a tire chirp, that means you're loosing traction. Which also means you're right at the edge of traction to begin with. The first thing I would check is toe in.
jimmyd
01-27-2009 01:55 PM
P.O.R.
15
06-30-2004 04:16 PM
psalm69
03-27-2004 09:25 AM
BigBlue
03-22-2003 12:45 PM
Quick Reply: Handling problem
