GSK springs
Old 02-28-2008, 10:53 AM
OutlawStorm's Avatar
GSK springs
I am playing with a truck that has had the GSK 3000 kit already installed in it. My Question is What are the symptoms if the springs are too tight and also if the springs are to loose? Is there a benifit if they are say 1 click looser or 1 click tighter?
Thanks for any and all help
Old 02-28-2008, 01:55 PM
xzaq103's Avatar
When mine in the 97 were too tight it made it idle at about 550 RPM.
Chris
Old 02-28-2008, 02:01 PM
blueboy16's Avatar
When i had 98 and i had the springs too tight it would idle fine but as soon as you touched the throtle it wouls idle up to 2k and stay till you put a load on it.
Old 02-28-2008, 02:20 PM
b.lee's Avatar
Chris
Same on my 96
We bumped up the idle screw a little.
Problem solved.
Old 02-28-2008, 04:39 PM
xzaq103's Avatar
Mine would wind two 2k as well after tring to tweak the idle screw.
siebertl
06-10-2007 02:29 PM
SHARPMACHINE
03-06-2007 08:45 AM
plow
08-09-2005 04:25 PM
MR HYDROSEED
03-09-2005 10:49 PM
Got Smoke?
10-26-2004 03:57 PM
Quick Reply: GSK springs
